How many liters of oil does 206+ take? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 17:09 | # 1 |
| 08.05.2020 17:09 | # 2 |
Alicilik |
In 2500 maintenance, when the bar was above 3 quarters, they added half a liter. In oil change, they completely poured 4lt canister with 150ml additive.
| 08.05.2020 17:09 | # 3 |
The vehicle in the signature gets 3.2 LT, how long has it been? If it is too little, it will not hurt. |
| 08.05.2020 17:09 | # 4 |
[QUOTE = Appealing] In the maintenance of 2500, when the bar is above 3 quarters, they added half a liter. They poured the 4lt canister in the oil change with 150ml additive. They fill it up completely, I think your friend is a gasoline vehicle |
| 08.05.2020 17:09 | # 5 |
Alicilik |
[QUOTE = Serco05] Diesel takes 3.8 LT Ali, but they put 4 LT, they fill 4 lt fully, I think your friend car is gasoline [/ QUOTE] It's true I thought the same is the same . I asked him to go above the normal level of the bar after the maintenance, the engine throws itself to the master, he said. I said from inside what was the euro4 engine bea |
| 08.05.2020 17:09 | # 6 |
[QUOTE = Buyer] [QUOTE = Serco05] The diesels get 3.8 LT Ali, but they put 4 LT, they fill 4 lt full, I think your friend is gasoline [/ QUOTE] It's true I thought it was the same. I asked him to go above the normal level of the bar after the maintenance, the engine throws itself to the master, he said. I said from inside, what was the euro4 engine bea [/ QUOTE] I would say if you were in Istanbul we are going to the same master, singing the bear in my master |
| 08.05.2020 17:09 | # 7 |
They put 3,200 lt as you said, but it also exceeded the upper limit of the bar. I don't believe the master says he throws himself. I know I think it's wrong
| 08.05.2020 17:09 | # 8 |
It doesn't matter how many liters it takes, but how many liters it can be filtered. The crankcase plug opens and awaits creeping. After a while, it is closed and top filling is started. After being placed as far as Suzulen, look at the level of the cube and add it gradually until it reaches the appropriate level. The truth is like this.
| 08.05.2020 17:09 | # 9 |
nobody does it like this. what should i do if bizraz & nbsp; empties & nbsp;
| 08.05.2020 17:09 | # 10 |
Brothers, I bought my new vehicle & nbsp; 206 1.4 HDI XT vehicle bought oil change, but how much will it cost anyone? & Nbsp;
| 08.05.2020 17:09 | # 11 |
My last maintenance expense 4 months ago castrol edge 5/40 engine oil 69 TL Air filter 15 TL Oil Filter 15 TL Pollen Filter 10 TL Labor 20 TL Total: 129 TL |
| 08.05.2020 17:09 | # 12 |
_pathfinder_ |
I had 5 days ago Mobil 1 s2000 10-40. My car was 206 1.4 hdi. 4 lt completely dumped the level cub a little over. I paid 75 TL with oil filter. I changed air-diesel-pollen filters 1 month ago. It was gone .. & nbsp; By the way, my vehicle has a crankcase protection. Last winter castrol edge I had 5-40 cocks, I came across the master's vigor and pulled all the oil out of the machine when I took out the oil filter. lt oil had increased in the box.This time, he removed the caster and took out the whole oil from the bottom and the vehicle took 4 lt. A small amount of old oil left in the vehicle spoils the viscosity of that beautiful quality oil that has just been replenished. 5-40 oils are fully synthetic and more specific than others, I think there is no need to deteriorate the quality.
| 08.05.2020 17:09 | # 13 |
Thank you, my brothers are relieved for your information. My new questions may come & nbsp; |
