How many liters does the Partner Tepe 2012 gearbox oil take? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee | |
| 09.03.2022 21:23 | # 1 |
| 10.03.2022 09:40 | # 2 |
sonerkyl |
Hello, brother, even if we tell you the net amount, you will put too much, this time there is a possibility of bursting the felts. The oil filling plug helps the masters in measuring the level, and the filling is done until the oil flows from there. transmission oil capacity is better than 2 liters motul or mobile total.
| 13.03.2022 17:27 | # 3 |
Hello master! I have put a total of 75w80 in the car before, there is no problem when the car is cold, but when I take my foot off the clutch when it warms up, it makes a stylish noise, I took it to a master for a pressure pad change, we put the original pressure on the pressure Balat, this guy said to me, let's change the oil, it's black, so I change it so that our work will be clean. I said and he went, he put 80w90 without shame. After 3 days, the wheezing from the gearbox started to make a sound as if metal particles were entering between the gears. As you said, I'll put motul tomorrow, isn't there a solution to that clutch noise? In this new transmission, that stylish sound is coming when I take my foot off the clutch
| 14.03.2022 22:04 | # 4 |
slm bro, don't take the gearbox off for that sound. I have the same sound in my 2018 model partner. That sound comes from the clutch fork, even if a new ball is installed, I also removed it like you did, I replaced everything with a brand new original part. That sound continues. For gearbox removal but 75-80 for oil, motul is really good in this regard.
| 30.04.2022 20:41 | # 5 |
How many models of your sister vehicle, how many kilometers did you completely change the gearbox, and what was the gearbox failure in your vehicle, for example, I have a problem, at 60-70 km speed, there is a hum, whatever I did, we couldn't figure it out. I would be happy if you write how much it cost, I want to have it replaced, I didn't do the transmission as a last resort, what are the axles, axle balls, what are the axle balls, I changed the transmission oil 2 times, the transmission was removed once, that sound did not go away.
