How many km of pads change time?
08.05.2020 17:05 # 1
hakan38
I am very happy if there are masters who know how many thousand of cars are replaced in aceba at 37 000
08.05.2020 17:05 # 2
hsnsnl
I think it kills 100 000 km
08.05.2020 17:05 # 3
Alicilik
[QUOTE = hsnsnl] I think it knocks 100 000 km [/ QUOTE]
brake or pressure, hod? = "smileys / smiley36.gif" border = "0" alt = "LOL" title = "LOL" />
I changed it in terms of 30000 master said just in time, the pad part was less than 1mm
08.05.2020 17:05 # 4
tellotello
Mine was making sounds, we lifted the fiber, the master said both the lining was finished and the discs (for the front). If there is a sound, it will change definitely, the tool change has already told me. I think a good amount of 40000 km does not go 100 thousand. Also, the important thing was to wear an original or reliable brand, or it could cause problems.
08.05.2020 17:05 # 5
feline
changes even at 10,000 if you use multiple brakes or test abs continuously & nbsp;
08.05.2020 17:05 # 6
hsnsnl
[QUOTE = Receiveness] [QUOTE = hsnsnl] I think it will roll over 100 000 km [/ QUOTE]
brake or home?
come on, the brake pad has passed 100000km brake pad for discs even more than "LOL"
I changed it in 30000, the master said just in time less than 1mm lining pad < br> [/ QUOTE]
You had to understand that I wasn't talking about the brake pad, my dear friend I wrote for the drain pad ..
in the brake If the disks and pads are no longer visible, you can understand the condition from the rim by yourself.
08.05.2020 17:05 # 7
hakan38
Brother I say brake pad :) Let's not allow misunderstandings
08.05.2020 17:05 # 8
loiz
Brake varies according to your use. You have done well again, not too costly, but it is important. Change your origins. I will spend one of the cars either, but good.
08.05.2020 17:05 # 9
GokhaN
The brake pad varies depending on usage, but it is changed every 20 thousand km.
08.05.2020 17:05 # 10
cerci07
I have traveled 145 thousand km with the fiesta I sold, neither changed the brake pads nor changed the flywheel and drain pads in the past due to the flywheel failure.
& nbsp; what they say is good, the brake brake is less, I can easily roll 100 thousand km "Big
08.05.2020 17:05 # 11
[QUOTE = loiz] depends on your braking use. You have done a good way again, not too costly, but it is important. I'm going to spend one or two of the car or the car. [/ QUOTE]
It has been 8 months since I changed this pearl, and this was the attention of your vik vik singing event. I have the same problem. that is, the sound is coming from the left front wheel while slowing down this edition is relevant to my pad. I went to the master, he tried to speed the news because of the demonstration, there was no sound. We took 10 laps, no sound. I'm going, I'm cutting my speed vik vik sound is coming. I wonder if that ??? What would it cost if he did?
08.05.2020 17:05 # 12
[QUOTE = loiz] depends on your braking use. You have done well again, not too costly, but important. "4"> while going very slowly now vik vik vik ötüyo .. i will spend the car or one of the two, but good. [/ QUOTE]
& nbsp;
& nbsp;
this vik is also viking when it goes slow. I wonder for the same reason? What is the cost ???
& nbsp;
& nbsp;
