How many km can be reached when the light is on?
08.05.2020 15:49 # 1
Friends, I will calculate the fuel consumption, but when I get the light, I get it right from my fear. But when the light comes on, the needle does not come to an end.
08.05.2020 15:49 # 2
Also, for example, when I buy 20 TL gasoline, the light does not go out immediately.
08.05.2020 15:49 # 3
berk2309
It is calculated according to the rotation of the wheels, after the time of the gas in the tank, after the light burns down, how much it will change according to the bass, also because it is possible to fall under the tank as much as possible or burn the light because the gas pump will cool itself with the gas in the tank, if it is less, it will burn the pump.
08.05.2020 15:49 # 4
Let me get it when the light is on, is there no gas in it?
08.05.2020 15:49 # 5
berk2309
the gas remains, but the gas is low in the tank, and the tank bottom is pulling the filter is clogged, this time the gasoline is low, this is burning the pump
08.05.2020 15:49 # 6
metin
The light is on before about 50 km of petrol. how many models of vehicle. In 2003 and above models, even the brain of the car decides to light, so when it uses calm, when the light is on, it shows a path of 100-120 km. When it is used aggressively, when the light is on, the computer shows 40 km.
In older models, the pointer burns down to a certain level because it is connected to the float instead of the brain. Likewise, when the light is on, if you use it calmly, you will go 80 km in 80 seconds, if you drive fast, you go 40 in 50 seconds.
08.05.2020 15:49 # 7
It means the 2000 model 1.4 8v is according to the float because it is on the ground in red.
08.05.2020 15:49 # 8
forewer_fb
When the light in my car's booklet turns on, the amount of fuel left in the tank seems to be 6 liters. However, it should not be forgotten that the gas pump may also be misled according to its life.
08.05.2020 15:49 # 9
When the light turns on 50 km definitively?
08.05.2020 15:49 # 10
cetin
[QUOTE = text]
In older models, the pointer burns down to a certain level because it is connected to the float instead of the brain. Likewise, when the light is on, if you use it calmly, you will go 80 km in 50 seconds, if you drive fast, you will go 40 in 50 seconds.
Is this valid for Master, Lpg, so how much does it go when the light goes on?
08.05.2020 15:49 # 11
metin
It also changes in lpg. If you press the red light, it will not go even 50 km. If you do not, you will exceed 100 km, everything depends on the user. you can find the right answer by analyzing it yourself.
08.05.2020 15:49 # 12
cetin
In the master LPG, it is not necessary to overload the gas for the vehicle to burn less. Is there any other saving methods. I sometimes root the gas. Ying Yang
08.05.2020 15:49 # 13
forewer_fb
[QUOTE = husames27] When 50 km clear light goes on? [/ QUOTE]
It would be wrong to say something right now, the tanks of the 306s are 65 liters, after the light turns on, 6 liters remain about 10%. How many liters is the 206's tank? may be less after the light is on. I think you can do the best test yourself, take 20 TL of gasoline into the gas canister, put it in the trunk, reset the km as soon as the light is on, see how many km you will be on the road, continue with the spare gas when you are on the road :)))) Note the terms of use.
08.05.2020 15:49 # 14
If your goal is to calculate fuel, you don't have to cut the gas Kahkaha
Fill your tank to the mouth of the lid. Destroy 300-500 km after that. Then, just fill the previous one, fill it up to the mouth. If you bought Kac lt benzine, make your calculation according to km or g ...
If you want to learn how many kilometers you can do with a tank, it is already obvious that the tank of the vehicle takes a few liters. When you find the consumption rate, you will rate it with the fuel that the tank receives. Göz Kırpma In this way you will find how many chlometers you can go ...
08.05.2020 15:49 # 15
forewer_fb
I guess cem can know more or less how many kilometers his uncle has done until the last drop, so how many km can go after the light
08.05.2020 15:49 # 16
Or because filling the tank in gasoline does not cost every father, he tries to find a solution to his problem in a short and cheap way.
[QUOTE = forewer_fb] cem I think his friend's uncle can more or less know how many km he has done until the last drop, so how many km after the light [/ QUOTE]
08.05.2020 15:49 # 17
Let me ask you for the sole vehicle, I was on the way to the bug, I did not stay on the road, I was afraid like it. Be sure when burned 50 km does not make it, but the risk of staying is too much, but as I said, do not be afraid when your warehouse is full, and your gas is full when you have it.
08.05.2020 15:49 # 18
orhanax
& nbsp; To the bottom of the warehouse is inconvenient and unnecessary. There is a risk of the fuel pump being burned when the vehicle is left without gasoline, or the residue at the bottom of the tank may block the fuel filter. I calculate the fuel consumption: we fill the tank fully and reset the odometer, when we fall below the quarter tank, we fill it again. When we divide the total fuel we received in the second filling into the kilometers we make, we find out how many liters of fuel we use per 1 km. When we multiply by 100, we find how many liters we burn per 100 km.
08.05.2020 15:49 # 19
At least, but when the light burns, they don't see the bottom, I think I went to the nearest oil office, I went to the nearest oil office.
08.05.2020 15:49 # 20
orhanax
As you said, Ahmet. It is not clear what will happen on the road. It is good to be cautious.
Page : / 2
