How many kilometers does it go after the light turns on?
08.05.2020 15:14 # 1
BERKAN
hello my question will be that 2005 model 206 has hdi how many km goes after the fuel light burns, does this vehicle have any test or knowledge?
08.05.2020 15:14 # 2
oguzhan29
I was burnt, I went 65km in the city but it was burning, I said I was full in oil, what would happen, it would take a long time but it would take a lot more because it takes 80-120 on the long road when the lamp turns on
08.05.2020 15:14 # 3
metin
his answer is very difficult because it depends on usage.
If the vehicle is loaded, the road you go is ramp, if it goes 50 km, it goes 25 km.
In other words, the way you hit the gas stops and stops, but changes at least 50 km under normal conditions.
08.05.2020 15:14 # 4
BERKAN
So let's start with an account like this: how many pounds are left in the warehouse, the lamp is on. We can make a clearer cut here ..
08.05.2020 15:14 # 5
Serhun
Normally I know that every vehicle is 40 kilometers (of course the conditions of use are important)
But most importantly, after trying this and filling the dirty fuel in the tank into the car, the problems are solved.
08.05.2020 15:14 # 6
metin
Well, since the float system in these pejos is a little different, I say it changes according to the way you press the gas again.
For example, in 307 cities, after the lamp is lit, it does not show that I will go for a few km with the warehouse, but it says that even if I go at a constant speed on the long road, the lamp goes 120 km.
but normally it burns when there is enough fuel left to go 50 km.
If I am wrong, my friends correct it.
08.05.2020 15:14 # 7
klemann
once in my 206 diesel city 65 km had gone
08.05.2020 15:14 # 8
Turns on the light when 100km remain on the trip computer.
08.05.2020 15:14 # 9
Yusuf Tekoglu
I am 35 KM Die biliood I was wrong I mean I was wrong I was so :)
08.05.2020 15:14 # 10
klemann
[QUOTE = Yusuf Tekoglu] I am 35 KM Die biliood I was wrong So I am so wrong that I was wrong :) As soon as the light is on, I am entering the nearest simulator. [/ QUOTE]
I think you are doing the best. There is no need to pull the dirt in the tank, it is best not to drop the quarter.
08.05.2020 15:14 # 11
Yusuf Tekoglu
Last Week's Brother's 3.18 Vehicle's Gas Pump Burned 220 TL 30 TL Workmanship Lady 250 TL Come on Get Well .... I don't think Peugeot will surpass him.
08.05.2020 15:14 # 12
tigerland
I once tested it on my 1.6 8V 206 vehicle. the light went on I passed 77 km, but before I was finished, I went into gasoline.
08.05.2020 15:14 # 13
d3n1s
I went to the city 65 km with 206 1.6 16v. When the light comes on, when I enter the gasoline I find and fill the tank, I get 38-40 liters of gas, which means that when 8-10 liters of gas remain, the light turns on. (as far as the tank is 47 liters)
08.05.2020 15:14 # 14
burakdmr
Well friends my vehicle 07 comfort manual gear 1.4 gasoline .. I think 60 lt gas tank .. How many kms of a tank with petrol ??
08.05.2020 15:14 # 15
Muhammet CAKIR
My light never goes out :))) I'm throwing 10-15 TL.
08.05.2020 15:14 # 16
slnysf
I know the factory data is 50 .. but I know that I have to go 90 100 km from compulsory .. but I do not recommend to go when the light is on .. the diesel pump is likely to burn because it ..
08.05.2020 15:14 # 17
burakdmr
DO YOU KNOW THAT :))
08.05.2020 15:14 # 18
acad
There is no point in traveling in a tall way after the light is on in diesel vehicles. If you continue to drive your vehicle, when your diesel runs out, there is a possibility of damaging the diesel pump and injectors, which I wouldn't recommend at all, you would spend a lot for 3 cents.
08.05.2020 15:14 # 19
F-Eren
trip computer shows between 80-100 when the light turns on and I went 80km once
I have also witnessed the reality of the on-board computer 206 many times. 80 km goes under normal conditions
08.05.2020 15:14 # 20
Sonmez
Thanks for the information
Page : / 2
