How many degrees does the fan open? |
| 08.05.2020 18:42 | # 1 |
| 08.05.2020 18:42 | # 2 |
Just as the mechanic is right, he turns on the fan after 85, but it is not normal for him to turn on after 90, but after 95, it can create different results for the vehicle in the long term. |
| 08.05.2020 18:42 | # 3 |
What is your vehicle model
| 08.05.2020 18:42 | # 4 |
TaZ |
the first fan comes into play in 90 odd ones that I know is 102 degrees and the second fan comes in. I know that all pejoes are the same and if you examine the site something normal in everybody's car, there are many issues about this topic and it is the same as everyone else.
| 08.05.2020 18:42 | # 5 |
Barut |
The first fan enters at 97, the second enters at 102, this is the original. The fan opens at 97 drops to 90, that is, plays between 90 and 100. |
| 08.05.2020 18:42 | # 6 |
teacher, how is the speed of the fan running slow or does it run fast and loud?
| 08.05.2020 18:42 | # 7 |
The fan is quiet..the first fan opens around 94-95-97 as you say. 2. Fan has been heard 3-4 times for 4 years, but I know and I know ... as far as I understand you say there is no problem everything is fine :) so it will not be harmful .. this is the original
| 08.05.2020 18:42 | # 8 |
akantek |
In my opinion, even when it reaches the normal 95, my does not open. it depends on the temperature. There are even summer and winter varieties. fan activation temperatures are different. I think you don't have a problem right now
| 08.05.2020 18:42 | # 9 |
there is no problem, first level 97 is open to death
| 08.05.2020 18:42 | # 10 |
There is no summer thermostat in the pejo. Open the 2nd level in 105. Generally, there is no need for 2nd Stage. Do not be afraid of the heat I climbed at 40 degrees, it lasted for 110, but it did not get higher.
| 08.05.2020 18:42 | # 11 |
Mine is opening at 95 is normal.
| 08.05.2020 18:42 | # 12 |
I do not think that my car 2000 model has much to do with this model. It is not a problem because of me and most peugeot vehicles around me are as alone as I described. |
| 08.05.2020 18:42 | # 13 |
[QUOTE = samet206] I don't think that my car 2000 model has anything to do with this model. It has been adjusted according to the temperature, so there is no problem for me and the fan opening style of most peugeot vehicles around me is as I described. [/ QUOTE] peugeot engines are highly suitable vehicles. It is designed this way to make fuel economy. old type vehicles can open as you say, but i have not seen a fan that opened the 85 degree fan. As far as I know for years, the first stage fan comes into play in 92, and the second fan, which is high in 97, comes into play. Thank God I had no trouble. I wouldn't lie if I said I have never heard of the second fan to this day
| 08.05.2020 18:42 | # 14 |
[QUOTE = ertanakar] hello friends. 2005 model pejo 206 1.4 on my gasoline car, the fan turns on when the water level is at 95. The teacher says that this is not normal, it should turn on at 90. In this way, it is more likely to heat. but for the second time, I changed the thermostat bill, and in the same way, a fan was installed to open the original at 95. I want to ask, is your vehicle the same way [/ QUOTE] Do not worry, my peugeot peers do not burn the engine, especially the 206s, don't be afraid, there is no 206 that burns the engine so far, the reason for the high temperature is designed for fuel economy. my car turns on the first fan at 92 degrees. If I say I have never heard of the second level, this is the place. If you park your vehicle when the first stage fan turns on, it will stop at the fan. Do not worry, this is the working system. motor aluminum block quick sogur. If the second stage fan stops, it does not stop when it stops, it continues until it lowers the heat. If you are using peugeot, you will get used to it over time do not worry no problem |
| 08.05.2020 18:42 | # 15 |
my teacher is in the first level 110 in 97, the second stage comes into play
| 08.05.2020 18:42 | # 16 |
This means my car can not be known in this way, and these rates may vary compared to vehicles with different styles and different engine power. I would like to mention again. I am not saying that it opens at 85 degrees. .In some cases, it can pass, as you say, it turns on at around 100 degrees. There are people in the environment around me. The friend who opened the subject states that he opened the fan at 95 degrees. I think a high value for the first fan at 95 degrees, I say my opinion and what is in my car, but also in my car history I would like you to see ... Brand is in my model signature. |
