how is this malfunction ...
08.05.2020 19:53 # 1
abokam
friends, help me, I would be happy .. 206 hdi 2007 model car sole, there is a problem, I run the car when I work, I press the throttle when there is no reaction, I still turn off at idle, I press the car again at the idle, I press the throttle no reaction, I just shut off the starter again, I started again, I press the gas again, do not press it again in the presence of idleness. Then I turned it off again, this time froze back to normal. What should I have caused?
08.05.2020 19:53 # 2
abokam
urgent help friends ...
08.05.2020 19:53 # 3
GokhaN
If there is a problem with the diesel pump, I think
08.05.2020 19:53 # 4
and the accelerator pedal wire is yours. the tool
08.05.2020 19:53 # 5
ymehmet
There may also be an eccentric shaft malfunction. Now, I think, without wasting time, go to the master and connect the car to the computer. Get well, hodja.
08.05.2020 19:53 # 6
abokam
tskler friends I wonder if it could be from egr valve
08.05.2020 19:53 # 7
abokam
accelerator pedal with wire
08.05.2020 19:53 # 8
ALLEX
[QUOTE = I aboka]
accelerator pedal wire [/ QUOTE]
The strongest possibility is the gas pedal wire
Then diesel pump and fuel filter control.
Get well soon. If you later share how you solved the problem under this heading, it will benefit other friends.
08.05.2020 19:53 # 9
abokam
I made the vehicle malfunction, the trouble was to have three injectors missed, I cleaned it, and I made the legs, it just got better.
