How is this? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 16:48 | # 1 |
ufuk91 |
Reviews
| 08.05.2020 16:48 | # 2 |
The pipe incident allows it to remove the filter from the side of the engine and reach cold air, I did not find this direct connection healthy, it is hot as hell in this area, I think it is not efficient.
| 08.05.2020 16:48 | # 3 |
ufuk91 |
Do you have it, hodja, and I said, does not normally connect 2 pipes from the bottom of the filter before the butterfly reaches the butterfly with the pipe. how could i not understand this process
| 08.05.2020 16:48 | # 4 |
metin |
It was a very bad connection. The fuel rises a lot and drops down the traction (: There is a pipe coming from the engine before it gets there, which causes the oil vapor to escape from the engine. & Nbsp; < / div> When a straight pipe is installed, the tip of the pipe coming from the motor is idle, so that filter is installed there. Small filter in the picture, < div> |
| 08.05.2020 16:48 | # 5 |
ufuk91 |
eccentric filter or what do they say? Yes, I saw the person who did it in a picture, but my teacher also comes a pipe from me.
| 08.05.2020 16:48 | # 6 |
metin |
[QUOTE = ufuk91] eccentric filter what do they say? Yes, I saw a person who did it in a picture, but my teacher also has a pipe from me. I know that the camshaft is for the oil mist there. That's why those who install straight pipes install an eccentric filter in the place from the camshaft. & Nbsp; is the first time I hear the second pipe you mentioned. Can you see exactly where it came from?
| 08.05.2020 16:48 | # 7 |
tigerland |
This is the first time I have seen such a link :)
| 08.05.2020 16:48 | # 8 |
ufuk91 |
[QUOTE = text] [QUOTE = ufuk91] eccentric filter, what do they say? Yes, I saw a person who did it in a picture, but my teacher also has a pipe from me. I know that the camshaft is for the oil mist there. That's why those who install straight pipes install an eccentric filter in the place from the camshaft. & Nbsp; is the first time I hear the second pipe you mentioned. Can you see exactly where it came from? [/ QUOTE] My teacher is coming from somewhere below, and there is a connection for him in the connection pipe at the moment, let the vehicle come today (my father is now) I will take your photo and share it here. I will ask for my links, advice. Let me take a photo from here & nbsp; |
| 08.05.2020 16:48 | # 9 |
sedataksu |
Interesting link. & Nbsp;
| 08.05.2020 16:48 | # 10 |
ufuk91 |
http://forum.peugeotturkey.com/forum_posts.asp?TID=23125&PN=3&title=206-monza-ak-hava-filtresi pictures on this topic I threw up the teacher, you can look |
