How is the throat butterfly adaptation done?
08.05.2020 17:16 # 1
kuantum
We cleaned our throat butterfly. Then I do not know if adaptation has been done or not. Technically how is this done? If I take it to a master, can I just adapt without cleaning it again?
08.05.2020 17:16 # 2
ufuk91
[QUOTE = quantum] I cleaned our throat butterfly. Then I do not know if adaptation has been done or not. Technically how is this done? If I take it to a master, can I just adapt without cleaning it again? [/ QUOTE]
does it. Connecting to the computer is not a difficult process. I do not know the technique exactly, you do not need to know it, tell the master, connect it to the computer and handle it, if you are curious, follow your master on this subject :)
08.05.2020 17:16 # 3
hakan38
What is the use of changing my throat butterfly?
08.05.2020 17:16 # 4
SZKR
I know I need to have a licensed Peugeot Planet PP2000 software, I may know the name wrong. 3-4 minutes & nbsp; running & nbsp; works & nbsp; while the vehicle is connected to this software and simply updating the air-fuel map according to the measurement values of the sensors in the air inlet and exhaust outlet in the ECU.
08.05.2020 17:16 # 5
kuantum
[QUOTE = hakan38] What is the benefit of replacing my throat butterfly? [/ QUOTE]
is not to replace it, but it is necessary to clean it, it strengthens the vehicle's running and traction without idling. is definitely noticed. but after the cleaning, adaptation must be done.
08.05.2020 17:16 # 6
hakan38
Do you think the car is required at 40 000
08.05.2020 17:16 # 7
kuantum
[QUOTE = hakan38] Do you think the tool is required at 40 000 [/ QUOTE]
I think it is absolutely necessary. It will not harm, it will be useful.
