How is the gear knob removed?
08.05.2020 15:39 # 1
mimitt
Does anyone know about how the 308's gear knob is removed?
08.05.2020 15:39 # 2
d3n1s
I couldn't even remove the 206's gear knob with a pipe wrench, I asked the upholsterer, he said, we are removing it with the gear lever. Finally, I cut it out with a grinding machine.
08.05.2020 15:39 # 3
GokhaN
Let me explain the grudge of 206, I think it is the same.
After removing the blind with the plastic overlap on the bottom, you will roll up to the right side. In this way, you can easily remove it and this is the only way to remove the plastic underneath without breaking it.
08.05.2020 15:39 # 4
mimitt
The vehicle I have forgotten to write is the automatic transmission. But I think the same method will be valid.
08.05.2020 15:39 # 5
d3n1s
[QUOTE = GökhaN] Let me tell you about the 206's I think is the same.
The difference between those who know the job is there, but the master will have a question of mine, I couldn't even turn it with the pipe wrench 206, what did you turn the knob of?
08.05.2020 15:39 # 6
d3n1s
The point I forgot to write [QUOTE = mimitt] was the automatic gear, but I think the same method would be valid.
if it is automatic, let them get out of the room, at least if they do something wrong, you will have a contact person
08.05.2020 15:39 # 7
mimitt
When the sun comes to the chrome-plated area under the gears, it looks from time to time to prevent this, I plan to cover this area with carbon foil, now I am in zonguldak for the school, this service lies for now :) When I come to Ankara, we will be closer to the house.
08.05.2020 15:39 # 8
GokhaN
[QUOTE = d3n1s] [QUOTE = GökhaN] Let me explain the grudge of 206, I think it's the same.
With my hand, you pull it up and down half a turn, and you can translate it. Gülme
08.05.2020 15:39 # 9
mimitt
I'm trying and coming ....: 9
08.05.2020 15:39 # 10
Same event in 306 ???
08.05.2020 15:39 # 11
GokhaN
[QUOTE = by_ersin] this same event in 306 ??? [/ QUOTE]
It is the same. As far as I know the 206 and 306 gear knob system is the same.
08.05.2020 15:39 # 12
mimitt
I think it's not the same in 308, I think I cracked something, but it didn't come in general: 9
08.05.2020 15:39 # 13
oh man stop stop Sırıtma Ask for 5 minutes to come to the service .. they do not get money to ask ..
08.05.2020 15:39 # 14
d3n1s
[QUOTE = mimitt] 308 is not the same I think, I think I cracked something, but it didn't come in general: 9 [/ QUOTE]
My teacher Gökhan described it for manual gear, your vehicle is automatic. Of course it will not be the same. I think more tampering, it remains in your hands. Ask the service or a good upholsterer to describe it, or have it covered somewhere.
08.05.2020 15:39 # 15
mimitt
Even if the arm needs to come out, even if it is covered outside, otherwise there will be a two-piece heart that must be cut in the regions where the positions are. It is understood that when I return to Ankara, we will go to the service.
08.05.2020 15:39 # 16
OkaN
I removed the 306 gear knob, I said that I was gone, the nickle was gone, I broke the blind, the plastic in it was broken, can I supply them?
08.05.2020 15:39 # 17
I wish you had called us alo without doing it .. one evening you had met cem .. I was afraid to disassemble too. It took seconds to remove and install cecoli .. I think cecoli directly from the pocket or at pm .. it will tell you something definite. regards brother ..
08.05.2020 15:39 # 18
OkaN
The brother looked simple, I pulled it when the bidet knob was broken :( gone from the nerve blower .s
08.05.2020 15:39 # 19
At 307, you first remove the bellows from your nails and release it, then go to the back seat and viste in the appropriate position, hanging out with force.
08.05.2020 15:39 # 20
OkaN
i am crazy: S torn pff
Page : / 2
