How is the 2018 model allure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:18 # 1
kapadok
friends I found a 2018 model Peugeot 301 allure. I want to buy. At 17 thousand kilometers with 1.6 hdi engine. How does a car use?
08.05.2020 21:18 # 2
kapadok
I was between Egea and friends. On the internet, I looked at the fireplace a little bit, say egea instead of 301. But I like the 301 design very much.
Kapado 2020-01-21 12:42:47
08.05.2020 21:18 # 3
GokhaN
the wind is very inward and the case is very light I used it in 1 year if you are between egea buy
08.05.2020 21:18 # 4
I will not be able to comment so much since I don't use it, but we can say that it is better than 301 as egea insulation.
08.05.2020 21:18 # 5
Peugeot35
301 The new make-up case is wonderfully wind-repelled and made serious changes, no chronic problems, and it smells of fuel. As a result, 1.6 engine accelerates roots and is very comfortable with acceleration.
As for Egea, I speak for 1.3 diesel, the torque is good but it comes down to speeds on slopes and you can get off and get off on takeoffs. 1.3 It eats the turbo quickly because it has very little fuel consumption and the case is heavy. He has chronic problems. I don't have a safe case, but that car is hard with that engine. If you're going to get 1.6 then it's good but it's not kept unfortunately.
