How is my Amp and Subwoofer Selection?
08.05.2020 17:31 # 1
korkusuz202
hello friends now I want to buy this set I will get it immediately if I can balance my budget
the system in my vehicle & nbsp; pioneer mvh-1400ub + 16 cm alpine 220 watts + pandozit kenwood 350 watts
I am waiting for your suggestions, so both economical and high quality (normal level)
Pioneer-TS-W309D4-Subwoofer-30 -cmin Subwoofer Reviews JBL-GT5-a-604-4-Channel-Auto-Amplifier Cable Reviews Navigold-DS-08-Set Reviews
08.05.2020 17:31 # 2
emre_akdag
good luck already :)
08.05.2020 17:31 # 3
korkusuz202
Master, I have not received yet ...
If it is compatible and gives satisfactory sound, I will get it and expect the suggestion from you korkusuz202 2013-04-16 12:55:00
08.05.2020 17:31 # 4
Alicilik
The D4 dual coil is a good choice but this amp will not understand its fine tuning. I suggest you buy a mono block amp
Use either a quality 8gauge or 4 gauge cable set. If the fuse is not cut, get at least double 60a.
08.05.2020 17:31 # 5
audiocu
- Your amplifier will be insufficient, I would suggest 5 or 6 channel amps instead. For example, you can think of jbl gto5355.
For an entry level system, 4 awg cable is not needed, 8 awg is sufficient. However, if you turn to some familiar brands like stringer cadence ass.
Since the number of speakers is high, the number of RCA of the tape will be insufficient, then do not say "why there is not enough sound." I recommend you to buy a tape with 2 RCA output.
08.05.2020 17:31 # 6
EmSul
Since you think of a system at an affordable price, it is not possible to get a double amplifier or a good 5 channel amplifier, so do not choose your subwoofer as a pioneer 309d4, it is better to choose a subwoofer that will be compatible with 4 channel amplifier, for example Kicker comp12 or Rockford punch1 or Cadence fxs250..Anfi also Roadstar rda4060 or Edison 6040 work well, they are very affordable and work well enough with these bass. You can get 2 of these subwoofers and amplifiers with a cable set for an average of 350 lira.
08.05.2020 17:31 # 7
[QUOTE = audiocu] - your amplifier will be insufficient, I recommend 5 or 6 channel amps instead, because your system has 5 speakers in total. For example, you can think of jbl gto5355.
Since the number of speakers is high, the number of RCA of the tape will be insufficient, then do not say "why there is not enough sound." I recommend you to buy a tape with 2 RCA outputs.
08.05.2020 17:31 # 8
umut_25
has nothing to do with the subject, but a package like this caught my eye. How do you think this is?
08.05.2020 17:31 # 9
audiocu
[QUOTE = Alper`EN AKSU] [QUOTE = audio player] - your amplifier will be insufficient, I recommend 5 or 6 channel amps instead, because there are 5 speakers in your system. For example, you can think of jbl gto5355.
Since the number of speakers is high, the number of RCA of the tape will be insufficient, then do not say "why there is not enough sound." I suggest you to buy a tape with 2 RCA outputs. br>
of course my dear friend as usual you know this our job;)
