How is glass resistance made?
08.05.2020 17:13 # 1
furkanyakar
hi friends first. I just joined you. I have been with Peugeot 206 rolland garros for about 3.5 years and there are some things I know, we share it on good days, insha'Allah. The knife is thrown and a few lines do not function. What are they using for resistance, how can I repair it? If anyone has information, I trust myself, I will do it. now I throw the ball to friends who have knowledge :)))
08.05.2020 17:13 # 2
Barut
As far as I know the resistance cannot be repaired, the glass needs to be replaced.
08.05.2020 17:13 # 3
furkanyakar
yes there is no place to repair but what is the resistance material when i use a small amount there they will start working.
08.05.2020 17:13 # 4
There is a possibility of repair. Kits are sold for this.
http://www.amazon.com/Permatex-15067-Window-Defogger-Repair/dp/B000HBI9YQ
This is a kind of paint like nail polish. There are copper, silver or aluminum particles in this paint. The process is completed when you take a mold and paint the place of interest and dry it. If you throw a few, it is more solid.
08.05.2020 17:13 # 5
furkanyakar
this is super :)) thank you very much. With the help of paper bands, I draw strips under and above the lines on the glass, and I can easily paint. I guess it won't be a problem then
08.05.2020 17:13 # 6
[QUOTE = furkanyakar] this is super :)) thank you very much. With the help of paper bands, I draw strips under and above the lines on the glass, and I can easily paint. I guess it won't be a problem then [/ QUOTE]
Paint is important, but. There is a double-sided tape in my institution, but this double-sided tape is not made from a conductive material such as plastic, but a conductive material. Even I think it will work, but I have to try it "Smile"
08.05.2020 17:13 # 7
KenBlockJR
have a look at these products ..
http://www.hepsiburada.com/liste/loctite-arka-cam-rezistans-tamir-seti-2gr/productDetails .aspx? ProductID = otbkk501 & amp; categoryID = 20035763 & amp; SKU = OTBKK501 & amp; navq = fh_sort_by% 3d-_match_rat% by 252C-item_sale_count_pl 26fh_secondid%% 3dotbkk501 26fh_lister_pos%% 3D0% 26fh_locatio% of 3d 252F%% 252fcatalog01% of 252ftr_t 252F%% 2524s% I 253dca % 255cu0020resistans% 26fh_eds% 3d% 25c3% 259f% 26fh_refview% 3dsearch
http://www.hepsiburada.com/liste/electrofix-rezistansiletken-tamir-edici-set-841526 /productdetails.aspx?productıd=otm841526&categoryıd=20035763&sku=otm841526&navq=fh_sort_by%3d-_match_rate%252c-item_sale_count_pl%26fh_secondid%3dotm841526%26fh_lister_pos%3d1%26fh_location%3d%252f%252fcatalog01%252ftr_tr%252f%2524s I 253dca 255cu0020rezistans%%%% 3d% 25c3% 26fh_eds 3dsearch 26fh_refview% 259F%
Reviews
http://www.hepsiburada.com/liste/startime-rezistans-v to -Conductive-repair-blocking sets / productdetails.aspx? ProductID = otbtc21547 281 & amp; categoryID = 20035763 & amp; SKU = OTBTC21547281 & amp; navq = fh_sort_by% 3d-_match_rat% by 252C-item_sale_count_pl 26fh_secondid%% 3dotbtc21547281 26fh_lister_pos%% 3D2% 26fh_locatio% of 3d 252F%% 252fcatalog01 252ftr_t% 252F%% 2524s% I 253dca 255cu0020rezistans%% 26fh_eds% 3dsearch 26fh_refview% 3d% 25c3% 259F%
08.05.2020 17:13 # 8
furkanyakar
I think it also works, but it doesn't act as a resistance at the points you connect. because it must be heated and effective with the resistance in the conductor. Can't I find this product in tr?
08.05.2020 17:13 # 9
furkanyakar
[QUOTE = KenBlockJR]
http://www.hepsiburada.com/liste/loctite-arka-cam-rezistans-tamir- set-2g / productdetails.aspx? ProductID = otbkk501 & amp; CategoryID = 20,035,763 & amp; SKU = OTBKK501 & amp; navq = fh_sort_by% 3d-_match_rat% of 252C-item_sale_count_pl 26fh_secondid%% 3dotbkk501 26fh_lister_pos% 3D0%% 26fh_locatio% of 3d 252F% of 252ftr_t%% 252fcatalog01% 252f% 2524s% 253dcam% 255cu0020resistans% 26fh_eds% 3d% 25c3% 259f% 26fh_refview% 3dsearch
http://www.hepsiburada.com/liste/electrofix-rezistansiletken-tamir- Curing-set-841 526 / productdetails.aspx? ProductID = otm841526 & amp; CategoryID = 20,035,763 & amp; SKU = OTM841526 & amp; navq = fh_sort_by% 3d-_match_rat% of 252C-item_sale_count_pl 26fh_secondid%% 3dotm841526 26fh_lister_pos% 3D1% 26fh_locatio% 3d% 252F%% 252fcatalog01% 252ftr_t the 2524s 252F%%%%% I 253dca 255cu0020rezistans 26fh_eds% 3d% 25c3% 259F% 26fh_refview 3dsearch%
Reviews
http://www.hepsiburada.com/liste/ startin to-resistor-conductor-and-repair-blocking sets / productdetails.aspx? pr oductıd = otbtc21547281 & amp; categoryID = 20035763 & amp; SKU = OTBTC21547281 & amp; navq = fh_sort_by% 3d-_match_rat% by 252C-item_sale_count_pl 26fh_secondid%% 3dotbtc21547281 26fh_lister_pos%% 3D2% 26fh_locatio% of 3d 252F%% 252fcatalog01 252ftr_t% 252F%% 2524s% I 253dca 255cu0020rezistans%% 26fh_eds% 3d% 25c3% 259f% 26fh_refview% 3dsearch
thank you very much I will place the order today. & Nbsp;
08.05.2020 17:13 # 10
Alicilik
My father used to use something for that, but I don't remember what exactly.
First He detects sensitive areas with a hand tool. It was like a pencil in a pencil style. Then he would mark the places where the pen warned and paint them with another pen. Aykut was like an alloyed substance, as he said in his brother, his color was bright. Reviews
