How is carbon coating done?
08.05.2020 15:24 # 1
tigerland
Hi friends
I bought carbon foil, I will cover the side mirrors of 3m style, how do I pay attention to what I do without potting, can I help my friends who have applied before :)
Thanks in advance :)
08.05.2020 15:24 # 2
There are industrial hairdryers to prevent it from potting. Generally it happens in those who make window films.
08.05.2020 15:24 # 3
vbmaster
If you want a look at http://www.dailymotion.com/video/xbptm7_arac-renk-degisimi-folyo-ile-araban_auto
08.05.2020 15:24 # 4
tigerland
How do I make all the mirrors in the mirror so many of the 206 mirrors? Also, doesn't the sheet drying machine see our business?
08.05.2020 15:24 # 5
vbmaster
Hair drying is insufficient, it needs more heating
08.05.2020 15:24 # 6
tigerland
Our job is hard then :)
08.05.2020 15:24 # 7
metin
give it to the master: D
08.05.2020 15:24 # 8
In fact, there must be a regulated heat gun in order to make these heat like butter. sheet drying machine is not enough ...
08.05.2020 15:24 # 9
tigerland
I bought one heat gun: I gave it to the master, 20 tl, I gave it to 40 tl heat gun.
08.05.2020 15:24 # 10
Come on let's come easy then :))
08.05.2020 15:24 # 11
Make the most beautiful yourself. Worst possible you'll do it again, but you'll learn Gülme
08.05.2020 15:24 # 12
tigerland
I had filmed on the rear windows myself before. I know the tactic will be better now with the gun. I shot a movie with glass :)
If it's nice, I'll give you for free: p
08.05.2020 15:24 # 13
vbmaster
Thank you :) good bye already ...
08.05.2020 15:24 # 14
tigerland
[QUOTE = vbmaster] Thank you :) bye bye already ... [/ QUOTE]
thanks :) Did I use camsil when coating the last question of the bidet so that it doesn't stick properly? If it dries, let me use glassy to stick it by taking shape with heat :)
08.05.2020 15:24 # 15
Kemanyak
As far as I know, camsil is not used in foils. The masters of the company, who are covering the videos of 3M Di Noc on Youtube, do not use camsil blah. I also covered the mirrors and the front console (ashtray air conditioner frame or something) but collecting the mirrors over time. I did it in the winter season, maybe it had an effect. I will try again in the summer. I have removed the mirrors or something and I advise you to do it on the vehicle or get help from friends. Because when stretching the foil you heat on the mirrors, the floor should be fixed. You can fix the remaining air with the needle tip. The image is unbearable, but very laborious. Good luck with...
08.05.2020 15:24 # 16
tigerland
[QUOTE = Kemanyak] As far as I know, camsil is not used in foils. The masters of the company, who are covering the videos of 3M Di Noc on Youtube, do not use camsil blah. I also covered the mirrors and the front console (ashtray air conditioner frame or something) but collecting the mirrors over time. I did it in the winter season, maybe it had an effect. I will try again in the summer. I have removed the mirrors or something and I advise you to do it on the vehicle or get help from friends. Because when stretching the foil you heat on the mirrors, the floor should be fixed. You can fix the remaining air with the needle tip. The image is unbearable, but very laborious. Make it easy ... [/ QUOTE]
Thank you very much for the idea, man, I thought about disassembling now I gave up. I hope I will get the result I want with a heat gun on the vehicle, the spoiler will be easy, but the mirrors will bother me, yet I hope it will be enjoyable :)
08.05.2020 15:24 # 17
Kemanyak
Yes, it is very enjoyable, if you work by removing the mirror caps in the mirrors, you can throw the small curves there, but be careful you have to be very kind to the nails.
08.05.2020 15:24 # 18
tigerland
OK thanks. I called one of the vehicle dressing companies, who said that there was no need for a gun, if the hair dryer was sufficient for carbon coating. the machine is only needed for a long time, only a high watt hair dryer to cover the mirrors will do its job, I cancel the machine :)
08.05.2020 15:24 # 19
yusuf206
I will close the hood, but they asked for 100TL, I gave up: I: D: D
08.05.2020 15:24 # 20
cesva25
while taking glass film Sırıtma When I saw the hair dryer, I was like that Sırıtma
Page : / 3
