How Does Windshield Vapor Go?
08.05.2020 20:32 # 1
307XS307
hi friends recently i went to antalya özdilek avm. I got out at around 8-9 in the evening and walked at least 500 meters at 50 degrees to where the car was. I got into the car with that heat and warmth of the body. The other side did not know. Of course, the doors and windows were closed and the windows of the car became steam due to that body's temperature . It's been 2 weeks, still not over. On different days I tried to open the air conditioner on the glass with cold and hot, but still steam does not go. what should I do?
vehicle: 2004 model automatic 307 XS
08.05.2020 20:32 # 2
whisky
For these glasses, I think there are spray-style products that you can try to avoid misting.
08.05.2020 20:32 # 3
I think it is not very normal to have this steam in this strange heat. I wonder if a little amount of water is missing from the heater core. There were a few topics on the forum for steam. In addition, if my teacher's internal circulation is active, if there is no fresh air from outside, there may be such problems.
08.05.2020 20:32 # 4
307XS307
Internal circulation is not active, teacher. Also, there was nothing like this before. happened after talking on the phone for your car
08.05.2020 20:32 # 5
onlycihan
water, etc. spilled in the vehicle, if you have had something damp, this may have happened in the near future.
08.05.2020 20:32 # 6
Alicilik
There are moisture retaining stones in the building markets. Take them out and put them in the cup holder in the door of the vehicle.
If you are constantly operating the air conditioner, the air installation will sweat over time. The air filter may be wet. To do this, the air conditioner is switched off in an open place and after 30 minutes, let the car's internal parts dry and change the filter if possible.
Check the exterior drain holes of the vehicle If the rain is evacuated in rainy weather, the water will begin to enter the vehicle and you will notice this in very heavy rain.
08.05.2020 20:32 # 7
ahmet_bjk
It is very interesting that the steam does not go away
Either you give the fan to the glass or if you open the windows, steam goes away in 2 minutes or if we wipe it with a cloth, we will go away.
08.05.2020 20:32 # 8
ben_erhan
There may be water or moisture in the vehicle, your pollen filter may be clogged ...
If you sweat excessively, the seat you sit on may be wet and there is a chance that it could not be installed. Open the vehicle doors under the sun and ventilate it well .. I think it will be the solution.
