How does the headlight assistant work?
08.05.2020 18:31 # 1
serkomser
Hello,
As far as I have read in the User Manual, your car is also called "Home follow me".
To do this, when the vehicle is in the stop position, the key is not on the ignition and the headlights are not on, say leave the longs on, says the longs but we can only crash but can we keep it on? Normally, this means whether there is no hardware.
I tried to train that headlight assistant, but I didn't want to be burned for long, I thought if the arm was broken, I wanted to ask.
In the meantime, I said that if you hold the shut down button on the cars, there is an automatic glass lift, you can not know how it works :)
08.05.2020 18:31 # 2
nedim83
Stop the engine. Make the selector with the headlight arm 1 time without removing the ignition. Then remove the ignition key.
08.05.2020 18:31 # 3
Bugra
When I make the selector when the key is not in contact, it is activated.
08.05.2020 18:31 # 4
nedim83
Try it without removing the contact.
08.05.2020 18:31 # 5
KILIC
After stopping the car, make the selector once without removing the key, then remove the ignition, the longs will remain on for about 40-50 seconds.
08.05.2020 18:31 # 6
serkomser
[QUOTE = KILIÇ] After stopping the car, make the selector once without removing the key, then remove the ignition. The lengths will remain open for about 40-50 seconds. [/ QUOTE]
I'm trying to do this, but don't the tall be left open? It doesn't stay with me. So, when the headlight lever is in the 0 position, the longs don't stay open.
08.05.2020 18:31 # 7
KILIC
I wonder if the timing guy has a problem. When he does this, the tall people must remain hungry for a certain period of time.
08.05.2020 18:31 # 8
serkomser
While the ignition is on, the lengths remain open, but as I said, the lengths do not stay open when the headlamp lever is in the 0 position.
How can I get the doors to be locked automatically right after take-off? In the forum, which is said to be held by holding the button on the chest for 3-5 seconds, do you have a detailed description of how I can do this?
08.05.2020 18:31 # 9
emrepunar
[QUOTE = eurest] Long stays on when the ignition is on, but as I said, long stays do not stay on when the headlight lever is in the 0 position.
When the vehicle reaches 10 km speed, hold the key of the automatic door lock button, which is the key, you will see automatically on the information screen.
08.05.2020 18:31 # 10
KILIC
The position on the headlight lever must be zero as well. In the locking of the doors, you will hold the door lock button in the center console for 6-7 seconds.
08.05.2020 18:31 # 11
serkomser
[QUOTE = KILIÇ] The position on the headlight lever must be zero as well, it is probably a problem with timing. In the locking of the doors, you will hold the lock button on the center console for 6-7 seconds. A voice called dong will appear on the screen, but it will write in English. [/ QUOTE]
Man, I think we couldn't get along :) I don't have any trouble with timing. The problem is related to the fact that the lengths do not get burnt when the headlight arm is 0.
I tried this morning for the doors, but how did I do the bones, how should I do, when the doors are locked, when the contact is open or closed, etc.?
[QUOTE = emrepunar] When the vehicle reaches 10 km speed, hold down the automatic door lock button, which is the key, you will see automatically on the information screen. [/ QUOTE]
I didn't try it when I left :)
Eurest 2014-05-08 12:40:22
08.05.2020 18:31 # 12
KILIC
Teacher, what is the model of the vehicle?
08.05.2020 18:31 # 13
serkomser
307 - 2004 BVA XR
08.05.2020 18:31 # 14
KILIC
There is a new noticed model in the signature. Let's investigate and see if this is in your vehicle, but it probably is.
With respect to the headlight, the headlight lever will be in the zero position and after you stop the car, you will make the selector without removing the key. My 307 was like this and the lamp was on for 60 seconds after removing the contact. I do it the same way in 207 im, it is now burning for 30 seconds and then goes out. Friends who know I don't know if there is a different way will most likely write.
Do not think the door lock event will happen while the car is running
08.05.2020 18:31 # 15
tolga.onal
Unfortunately, there is no automatic door locking feature in XRs. I know from my own vehicle.
08.05.2020 18:31 # 16
KILIC
[QUOTE = tolga.onal] Unfortunately there is no automatic door locking feature in XRs. I know from my own car. I was very busy [/ QUOTE]
Hodja was in my 2005 model XR. But I don't know if there are sub-models.
08.05.2020 18:31 # 17
serkomser
I think automatic locking should exist in 2005 if it is available in 2005. As a result, when the door remains open, it warns with the lamp.
I have not just landed in my car, the longs aren't open when the arm is 0. Regardless of whether the ignition is on or the key is on the ignition but the lever is not open when the lever is 0.
So are these features related to the software?
08.05.2020 18:31 # 18
tolga.onal
May not be in 2003 or 2004 may not be :) but headlights have to be in every car start the car then turn off selector just click once dipped headlights turn on for 40 seconds and this happens in most cars
08.05.2020 18:31 # 19
serkomser
[QUOTE = tolga.onal] It may not be in 2003 or 2004 may not be :) but there must be headlights it is in every car start the car then turn it off once to make a selector dipped headlights turn on for 40 seconds or so in most cars [/ QUOTE]
If it is easy, make it your car :) I'm in Ataşehir, I expect to drink tea. :)
08.05.2020 18:31 # 20
KILIC
[QUOTE = eurest] [QUOTE = tolga.onal] May not be in 2004 or 2004 may not be :) :) but the headlights must be in every car start the car then turn off the selector to turn it off once. QUOTE]
Brother, we are writing to you in the morning, neither tea nor coffee :))) your car is broken then what should I say :)))
Page : / 3
