How does the 307xr trip computer
08.05.2020 14:07 # 1
300yedi
hi ar road computer, I have bought the vehicle for 7 months and there is no yo computer. to activate the trip computer that has not already been in xr and activate the rain and headlight sensors =
com 2000, do I have to wear my piece?
Do you get stuck on xr?
Do I need to install software after it is installed?
If it happens to me, how will it explode?
08.05.2020 14:07 # 2
I think the sensors don't need much,
For the trip computer, it is sufficient to buy the wiper arm with a button and have a software update at the authorized service.
The wiper arm is 150TL, and the software update is 20TL.
08.05.2020 14:07 # 3
the_beKKo
If you mean the information about the mileage, fuel, instantaneous fuel situation, you know that there are xrs in our trip computer, we have 1.4 HDI xr 2005 model trip computer
08.05.2020 14:07 # 4
300yedi
I do not know what happened until 2005, but I do not know exactly what I want, but I want a road computer
08.05.2020 14:07 # 5
hasimayaz
The wide line display needs to be in XR. If there is no display, it needs to change + com2000, zero would be a bit costly. Maybe the Master has their hand.
08.05.2020 14:07 # 6
300yedi
Hasim brother I am in Bursa screen normal 307 screen I did not pay attention to all the same, I did not pay attention to the width of the computer, when the com2000 changes, I have to adjust it accordingly, I have to adjust it accordingly, I have to set myself xenon angel led stop again new week I don't have much money to wear them. My average average price is enough for me.
08.05.2020 14:07 # 7
Ozgur
com2000 original in service 550 tl..no need to change your screen.com2000 can be seen directly on the moment it is installed, you may need to introduce it ... no rain and headlight sensor in xr? i dont understand how to get started.but if your car does not have rain and headlight sensor com2000 can be taken a little more convenient. ... this is the full arm that I call 550 ... so the model that controls the sensors and so on ...
Also, I wouldn't advise you to get out because com2000s have a lot of trouble ... then you should not have a headache.
08.05.2020 14:07 # 8
peugeotefe
The signal lever I have in my hand is 100 TL.
08.05.2020 14:07 # 9
Onur
[QUOTE = hasimayaz] Wide line screen should be in XR. If there is no display, it needs to change + com2000, zero would be a bit costly. Maybe Efenin has his hand outs. [/ QUOTE] Can I change the com2000 to 206 xr and be a line screen trapping computer?
08.05.2020 14:07 # 10
Ozgur
Unfortunately, it doesn't happen to 206 under 2003.
08.05.2020 14:07 # 11
individual
[QUOTE = Honor] [QUOTE = hasimayaz] The wide line screen must be in XR. If there is no display, it needs to change + com2000, zero would be a bit costly. Maybe Efenin has his hand out.
It happens.
trip computers were added to both 206's and 307 xr's many times.
bsi also has an infrastructure in the brain.
The vehicle knows how many kilometers it burns, but it does not show you.
Unfortunately, not all equipment is available on all models for model grouping.
edit:
As it says freely, I think it cannot be applied to some 206 s. some of them are different.
individual 2010-01-03 00:41:43
08.05.2020 14:07 # 12
Hello EFE,
I have 307 2004 HDI 1.4 Envy. If I take it from the arm you want, will my trip computer be active?
There is a situation like the arm does not fit. How can we overcome it?
08.05.2020 14:07 # 13
Ozgur
YES IT WILL BE THE SAME ON THE SLEEVE OF THE SLEEVE HANDLE.
08.05.2020 14:07 # 14
qaan
Hello,
still have this wiper arm in hand ,,,
http://www.viakeo.com/kyoto/video/ind/wy-zg6mhlfe/peugeot_307,adding_trip_comput is
respects
qaaN 2010-08-04 10:47:31
08.05.2020 14:07 # 15
fatihgg
It was a snoring of the issue, but in 2003 307 1.4, did I have a way to run the road computer?
08.05.2020 14:07 # 16
metin
[QUOTE = fatihgg] It was to snore the subject, but in 2003 307 1.4, did I see the road computer, if I could not make the water key, I saw the ccom2000 coke, I have friends who can help. Tskler. [/ QUOTE]
If you can find it, you should find the tip of the wiper arm, and if your screen is 2 lines you should get 3 lines. Then you just need to connect and activate the computer.
08.05.2020 14:07 # 17
fatihgg
ahhh, if I find that tip, if I find it, I don't want anything else, I wonder if there are friends who can find the site on the screen with 3 lines no problem or who has applied it as soon as possible in 307 ??
08.05.2020 14:07 # 18
elerot
Guys I have 2003 307 1.4hdi xr if you have a button on the end of the right wiper arm, which means you have a trip computer. I just got it built and I'm using it right now. you just solve the problem with a software. In Ankara, I went to Simge Peugeot, they put on the plug in 2 minutes and opened my trip computer. I give the address open to those who want. I got it there for 20 TL. There were 150 people saying elsewhere. I was fighting. We knew something about Allah.
By the way, is there any model of my vehicle that can use headlight and rain sensor? There is a button on my left turn signal lever and this is a headlight sensor and when the kontok first level presses for 10 seconds, there is a sound, so they say that the headlight sensor is turned on. I haven't tried it yet. There is a rain sensor event like a bidet switch. Does anyone use it? How do I get activated or do I have to buy hardware for these 2?
elerot 2012-07-15 19:52:08
08.05.2020 14:07 # 19
[QUOTE = elerot] guys I have 2003 307 1.4hdi xr if you have a button on the end of the right wiper arm, which means you have a trip computer. I just got it built and I'm using it right now. you just solve the problem with a software. In Ankara, I went to Simge Peugeot, they put on the plug in 2 minutes and opened my trip computer. I give the address open to those who want. I got it there for 20 TL. There were 150 people saying elsewhere. I was fighting. We knew something about Allah.
The round thing behind the rear-view mirror is our rain-headlight sensor. If there is or not Smile The method you mentioned to activate the headlight sensor is correct.
In the meantime, please sign up for the link in my signature.
08.05.2020 14:07 # 20
elerot
[QUOTE = Koliva]
thank you so much teacher. This type of sensors were in the mirror, they did not need a break, to note this information to my mind: D I will check when I get in the car, but I don't think it is in my model?
Page : / 2
