How do you think the maintenance fee 206
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:55 # 1
Maze87
ze rot 2 pieces 60 tl
Front disc 2 pieces 75 TL
2 pieces of front lining 42 TL
Rear center 2 pieces 60
I'm in circulation 1 piece 100 TL
Timing set 165 tl
And the strap is 55 tl
Disc lathe 30 tl
I don't understand what it means 2 pieces 15 TL
Engine oil 5-30 125 tl
Air pollen filter 35 + 20
Timing set kit four wheels 350 tl
How do you think, how did I do these things? And then the car was more cumbersome than before. In the past, the gas was going to be agile when I pressed the gas now. I was cleaning the throttle. It shifted forward when the throttle was pressed in the gear, now it is going very idle now I press it, the throttle is rising but the gas hand is moving slowly like this.
DO NOT DEFECT I WRONG THE FORUM WRONG THE FORUM MY CAR 206
Maze87 2018-06-15 23:50:40
08.05.2020 20:55 # 2
luridline
material prices are affordable. I don't know if it is the original or sub-industry. Workmanship is not dena. It would be better if you put the engine oil 5-40. If it doesn't decrease, no problem. They pushed some price for 125 liras. But I think it's generally appropriate. I can not tell you about the cumbersome timing, if the timing is correctly installed, it is not a problem. Working sound improves even after fat
