How do you think the fuel situation?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 17:29 # 1
emeric
Hello,
3 weeks ago I received 208 1.4 Access 2012. Today I traveled 600 km and now it is 725 km. I was full when I bought the vehicle. Now he says I can do 300 km with the remaining fuel on the screen, but I can not believe that it is quite right. The fuel gauge (I found the level on the internet and tried to show it myself) is now here & nbsp;
When I finished, I bought 48 LT of fuel. Do you think its current position is normal? They say it will not reach real fuel without seeing 15.000.
08.05.2020 17:29 # 2
ahmet_bjk
First of all, you have not specified whether the vehicle is diesel or gasoline. If you want to get the right information, you will ask the right question.
You can find the answer to your question with a small account.
Find out how many LT of fuel your vehicle's tank is. Let's take 60 LT as an example)
The line you show is the limit of the fuel warning lamp burning. So there is as much fuel in your tank as you can go at least 100 km. (estimated 6-7 LT may vary by vehicle)
You traveled 725 km with 60-7 = 53 LT of fuel. So your vehicle burned 7.3 LT per 100 km. If you compare this result with factory data, you can make a comparison or understand whether it burns more or less.
08.05.2020 17:29 # 3
SDYMZ
If it is gasoline, I think fuel depends on using a good one. but if it is diesel it should go 1000 km
08.05.2020 17:29 # 4
emeric
The vehicle writes about 1.4 liters in the diesel, fuel tank booklet. Since it is a long road, was it so lit or new, for the first time I use diesel, it was too much for me. The vehicle was also 1 step below the full line before driving 600 km.
