how do you think
08.05.2020 18:08 # 1
SDYMZ
w309 d4 Pioneer bass
edison 504 amps
ts a6994 Pioneer oval
Waiting for your comments how do you think the cable and assembly 500 TL
08.05.2020 18:08 # 2
kursat3006
I think nice price
08.05.2020 18:08 # 3
Burak
I think it's good like all of them
08.05.2020 18:08 # 4
Alicilik
ideal for zero
08.05.2020 18:08 # 5
samet206
I guess it couldn't be lower if you normally take the second hand and go for 50 TL cable set and 50 TL for assembly, I think it comes to the same account.
08.05.2020 18:08 # 6
kuscu38
If the materials are zero, I think an affordable price when I say installation cable or something ...
08.05.2020 18:08 # 7
barishrocker
The price is affordable but the amp and sub are incompatible ... I don't think you will enjoy the front door speakers without changing.
08.05.2020 18:08 # 8
SDYMZ
Zero is not my car, brother-in-law Opel 2000 model Astra cd attached to it. but I think the bass did not fit much
08.05.2020 18:08 # 9
barishrocker
Let me say this. if the ovals and the subwoofer are connected to the amp at the same time, the amp cuts and protects itself. because the subwoofer d4, that is, double coil and 2ohm is connected. it protects itself because it does not support 2ohm on the bridge. your brother-in-law is probably having these problems right now ..
08.05.2020 18:08 # 10
SDYMZ
[QUOTE = barishrocker] Let me say this. if the ovals and the subwoofer are connected to the amp at the same time, the amp cuts and protects itself. because the subwoofer d4, that is, double coil and 2ohm is connected. it protects itself because it does not support 2ohm on the bridge. your brother-in-law is probably having these problems right now ..
[/ QUOTE] has had no problems so far, but I recently noticed that one of the ovals did not hear any sound from the amp output.
08.05.2020 18:08 # 11
EmSul
The amplifier has become very indifferent, it is very weak, it is incompatible with the devices and the bass ... Actually, the plumber who wears a double coil 4 + 4 ohm bass first ... There is a single coil 4ohm model of the same bass, it should be used that amphitheater but still it is very insufficient. If one of the bass such as es or comp or rockford punch1 is used, both the better bass sound will be obtained and the amphitheater would not be a problem. The price is the normal market price.
08.05.2020 18:08 # 12
EmSul
There is only one possibility that it will not protect the amplifier because it does not support the amplifier. In the system in our transporter, I connected 2 jbl 1202d bass of the 4 channel amplifier with 2 channels bridged, that is, I drove 600rms in 2hm in total, it does not support 2 ohms. but there is no cutting or any other problem we have been using like this for about 7 years
