How do you know the JBL 5355?
08.05.2020 16:10 # 1
mimitt
friends, I am thinking of buying a jbl 5355 brand amp. Is the device enough for 5 remaining and sub supported and bass control units, 2 sets of components and 1 25 30 cm bass? mimitt 2011 -09-27 13:44:50
08.05.2020 16:10 # 2
brutal
BASS MAKES PARAMPAR 2 SEAT THE COMPACT.
08.05.2020 16:10 # 3
sedataksu
I researched this product for a period.2 sets compenent 2 ohm 65 W & nbsp; 70 W is enough. If the components are 2 ohm, again 2 ohm 300 W 350 W bass works easily.
If the system you are thinking is 5 channels beyond that It would be better to use 2 separate amps instead of the amphitheater. You cannot run 2nd bass in the amphitheater. Let me specify it as a price. There are very different prices in the market in the range of 300 to 350 TL. > Number of Channels / Type
4 Full-range channels, 1 subwoofer channel
4- Ohm Power Output 55W RMS x 4 + 225W x 1, less than 1% THD + N
2- Ohm Power Output 75W x 4 + 360W x 1 less than 1% THD + N
08.05.2020 16:10 # 4
34sea45
[QUOTE = sedataksu] I researched this product for a period. 2 sets of compenent 2 ohm 65 W & nbsp; 70 W is enough. If the components are 2 ohm, 2 ohm 300 W 350 W bass works easily.
Beyond that, it would be more appropriate to use 2 separate amps instead of 5 channel amps. You cannot run 2nd bass in this amphitheater. Let me specify it as a price. There are zero different prices in the market between 300 and 350 TL.
Number of Channels / Type 4 Full-range channels, 1 subwoofer channel
4-Ohm Power Output 55W RMS x 4 + 225W x 1, less than 1% THD + N
2-Ohm Power Output 75W x 4 + 360W x 1 less than 1% THD + N
+1
08.05.2020 16:10 # 5
[QUOTE = sedataksu] I had researched this product for a period. 2 sets compenent 2 ohm 65 W & nbsp; 70 W would be enough. If the components are 2 ohm, 2 ohm 300 W 350 W bass would work easily.
If the system you think is beyond that, it would be better to use 2 separate amps instead of 5 channel amps. You cannot operate 2nd bass in this amphitheater.
& nbsp;
If a very cold system is not imagined, this amp will produce enough sound ...
& nbsp;
2 sets of mds and 1 bass gets a very satisfactory efficiency
08.05.2020 16:10 # 6
sedataksu
If you are going to buy a new compenent, I would recommend you to buy jbl.
08.05.2020 16:10 # 7
brutal
MY FRIEND DIP NOT TO ADD A NOTE, THIS LICENSE DOES NOT GO BEFORE THAT YOU WILL CONNECT A 1000 L BASS BASSING.
08.05.2020 16:10 # 8
34sea45
no music will be heard from the press roar + the bass will not feed this amp + I will get a kicker l7 instead of cadence 1000 watts :)
08.05.2020 16:10 # 9
brutal
If my friend tells me 2 comp, he wears two double audio system or he gets a monster sound. He runs the bass in 2 ohms because he bass 4 sets comp ca and can bass .. & nbsp; L7 does not perform L5 is very sweet .. jbl kcker shatters 38 ..
08.05.2020 16:10 # 10
[QUOTE = 34sea45] no music is heard from the press roar + the bass will not feed this amp + I will get kicker l7 instead of cadence 1000 watts :)
& nbsp;
I agree too ... +1
08.05.2020 16:10 # 11
5355 is a very good lecture, but its price may be a little too much, you can think of jbl 1004 + mono amp + bass
both feed 1004 100x4 I guess, you will get the mono amphitheater according to your head sierra titanium mono block is very nice but the price is high & nbsp;
regards "Blink"
08.05.2020 16:10 # 12
34sea45
If he tries more than 2 sets mid (75 80 rms 16 cm) and 1 30 cm 250 rms bass, he will switch the amplifier to protect the sound.
note: As you drop the ohms, your risk of burning bass and mid stomachs increases. It is also necessary to consider this. / editdat a>
08.05.2020 16:10 # 13
i think jbl 1004 + buy monaural amp jbl 1004 100rms x 4
08.05.2020 16:10 # 14
sedataksu
The middle class is a beautiful lecture hall.
Those who are at home will understand when they enter the street.
08.05.2020 16:10 # 15
34sea45
We had to dismantle a system when we received a 750 TL penalty to make it clear that we came to the neighborhood.
08.05.2020 16:10 # 16
sedataksu
Get well brother & nbsp; I got salt on the wound.
"Laugh"
08.05.2020 16:10 # 17
34sea45
No, I still laugh when I remember that day. 16 cm
2 sets jvc 3 way coaxsiel
pionner tss20
38 cm kicker L7
08.05.2020 16:10 # 18
brutal
Pioneer 6900IB 50W x 4
Xetec V200.4 50W x 4
Sierra Sa2050 800W x 2
Jbl Gto6508c 16Cm 210W 70 Rms
Cadence Xenith Xs452 10Cm 30 Rms
Cadence Flash Fxs-5K 13cm 240W 75 Rms
Boss Blade 12`` 1200W 600 Rms
Boss Blade 12`` 1200W 600 Rms .. See You With Me At The Closest Meeting Who Wants To Try :) We are just starting .. .. >
08.05.2020 16:10 # 19
34sea45
In my eyes, now the installation is 1 set mid 1 set column 1 bass, the rest is nothing but wasting money
08.05.2020 16:10 # 20
brutal
now you are concerned with home test systems rather than plumbing :)
Page : / 2
