How do I remove the antenna ???
08.05.2020 15:26 # 1
ose
How to remove the antenna you see
Uploaded with ImageShack.us
kankam_743 2011-05-18 02:15:27
08.05.2020 15:26 # 2
I will say how it was put on, and you will not know how it was put on. So I don't know.
08.05.2020 15:26 # 3
Do you want to insert the antenna itself completely or just the tip of the image there?
the tip should be screwed ... if you want to insert it completely, it would be bolted from that part of the ceiling.
08.05.2020 15:26 # 4
I think it was installed later since the sunroof is in the coverage area. They pity if they pierced the ceiling.
08.05.2020 15:26 # 5
[QUOTE = badires]
No, that antenna must be original. Since the ceiling hurts, it hurts from the antenna to the antenna ...
the cecol 2011-05-18 15:47:59
08.05.2020 15:26 # 6
ose
Friends, thank you for the answers. Today, I examined again under the flooring under the floor, there is a plastic screw that holds the antenna completely and we remove it by removing it. If you have the same, never force it from the top. Also, my antenna is original. When I disassemble, I put the pictures.
08.05.2020 15:26 # 7
Anyway, those kinds of antennas have to be held from the bottom, otherwise they won't stop on the ceiling :))
08.05.2020 15:26 # 8
ose
[QUOTE = CeCoLi] already have to hold that kind of antenna from below or it won't stop on the ceiling:)) [/ QUOTE]
Yoo man, you can do that, you can take that plastic cover off, you will see the screws. Or remember those in reno12 Sırıtma
08.05.2020 15:26 # 9
I didn't mean it would be a bolt from the bottom. I wanted to say no sticking etc. in a way, you have to hold on to the bottom solid :))
08.05.2020 15:26 # 10
When the side plastics of the sunroof passes through the antenna, I thought the ceiling opens up to where the plastics end.
