How do I paint my wheel covers?
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 18:56 # 1
emresensoy307
Friends, I want to paint my wheel covers. If I paint it with spray paint, do I need to put varnish underneath and the 307's wheel cover color is in matt gray.
08.05.2020 18:56 # 2
muro_60
Of course, it is not painted under the paint, it is thrown on top. If you want to say a primer, you can take a quality spray on the moire and paint it with a fine sand.
08.05.2020 18:56 # 3
emresensoy307
Can we find Astari in this car paint shop.
08.05.2020 18:56 # 4
muro_60
No need for lining, sanding thoroughly with sand, lastly sand with water paint is not a problem.
08.05.2020 18:56 # 5
emresensoy307
Thanks friends, where can I find this paint, I need to do it on Saturday
08.05.2020 18:56 # 6
muro_60
[QUOTE = pug206emre] Can we find this car in the paint sellers.Yes, I would say lining.
08.05.2020 18:56 # 7
Barut
First a fine sandpaper and then 2 coats of primer. Then 3 layers of rim paint. The last 2 coats of spray varnish. It is so simple, I recommend the motim as a spray. Gone is gone etc. You can find places like.
08.05.2020 18:56 # 8
Barut
But all of these dyes are around 20 lira. It makes 60 TL, I just don't know the value for the caps. You can not get cheap efficiency in spray paint.
08.05.2020 18:56 # 9
suppor
I painted the 206's black, first sand, then paint, but the places that do not touch sandpaper directly throw and weave with time.
08.05.2020 18:56 # 10
GokhaN
If your situation is suitable, buy a set of covers and paint it beautifully, the paint does not look like the original. Cheap paints do not provide the desired image. But if you do it yourself, take a fine water sander and deformation will go away.
08.05.2020 18:56 # 11
emresensoy307
Actually, I thought to buy a rim but I couldn't find the rim I want.
08.05.2020 18:56 # 12
serdaralisan
My friend does not need primer, sand the covers with 2000mm water sandpaper, buy spray paint on them, shine frequently.
08.05.2020 18:56 # 13
sezar206
My friend buy fine sandpaper is close to normal paper. Sand well after washing, so that no dust is left. You can find spray paint in many places 2 3 pounds box. Buy 4 boxes of 5 different colors. I dyed it white and used it for a year and now I used to sand a little more and paint it yellow. Use pretty dye paint. This is the picture.
08.05.2020 18:56 # 14
suppor
Master, I have painted the black covers now I want to turn white. How do you think it stops on the white vehicle?
08.05.2020 18:56 # 15
suppor
How do you think if the black of the caps are white and white?
08.05.2020 18:56 # 16
suppor
08.05.2020 18:56 # 17
serdaralisan
THE WRITERS IN THE TIRES, NOT THE WHEEL COVER OF THE WHEEL, WITH WHITE PEN, SUMMER DOORS LIKE BLACK BEAUTIFUL
08.05.2020 18:56 # 18
ERDINC
Even if the bolt heads are also chrome, it is also nice when rubber articles are added.
08.05.2020 18:56 # 19
sezar206
Why did you paint it black that if you disassemble the covers, the rim was already black. I think you will have to polish the tires constantly because it is glossy black. White did not know how to stop, m car can also drown white. I must see it, I am trying to visualize it. As if it wasn't too bad. I saw a white rim on a white car, it was nice before, but they were steel rims hungry, they had painted calipers or something.
08.05.2020 18:56 # 20
suppor
Exactly, it is necessary to silicon it constantly, otherwise it looks very dirty, I do not clean it because it is winter, but you are right.
the tin rims in the lonely place were so stiff that I even painted them from the beginning, I did not like the shiny black, I painted the covers
I also love the white vehicle, I love the white rim.
Thank you, the master said that he had written the pen on the top of the lane with a white pen.
Do you have a chrome bolt?
