How do I lower my vehicle?
08.05.2020 16:03 # 1
I want to print 307mi a bit, but I am not very knowledgeable about this.
What is the cheapest way, what are the drawbacks and what is the healthiest method and how much will it cost?
08.05.2020 16:03 # 2
eren8er
the healthiest sports bow is to wear .. the most unhealthy and cheap 10 lira by heating the springs.
08.05.2020 16:03 # 3
What harm does a master recommend to me to heat and drop the bows instead of cutting them?
08.05.2020 16:03 # 4
MaximuS
I think absolutely sports bow ... other roads are very unsafe, inconvenient for the vehicle and extremely disrupt the comfort ... !!!
08.05.2020 16:03 # 5
eren8er
[QUOTE = HuseyinTurk] What kind of harm does a master recommend to me to heat and drop the bows instead of cutting them? [/ QUOTE]
There must be a problem with the master recommending heating the spring! If you heat the shaped material by heating it up after it cools, it will break again.
eren8 is 2011-08-26 02:03:43
08.05.2020 16:03 # 6
The sport is very hard on the bow, the car is shaking like a cradle. I don't like it, but I think there will be a loss of comfort anyway.
08.05.2020 16:03 # 7
MaximuS
[QUOTE = HuseyinTurk] Sports is very hard on the bow, the car is shaking like a cradle, I don't like it, but I think there will be a loss of comfort anyway [/ QUOTE]
false...
1. You will definitely use EIBACH once
2. You will not necessarily drop the top of the tires until they are covered, and if possible, use prokit (3 or 3.5 cm). Remember, the longer the drop you drop, the more the stretching area in the spring will decrease for its suspension.
08.05.2020 16:03 # 8
I think very lightly, the hood is grinning enough to cover it a little bit enough to fall as much as 2 people sit in the back seat like me.
08.05.2020 16:03 # 9
eren8er
If you have decided to lower your car, you will definitely compromise on comfort .. you should choose either comfort or image ..
08.05.2020 16:03 # 10
Your Vehicle is Already Very Low; Huseyin (:) the albaydemirc 2011-08-26 02:18:08
08.05.2020 16:03 # 11
Alongside yours, my proud car is officially crawling on the ground.
08.05.2020 16:03 # 12
I compromised comfort in the selection of rim tires, I chose the image, if I do so in the spring, it would be like a truck car
08.05.2020 16:03 # 13
MaximuS
If you have decided to lower the [QUOTE = eren8er] tool, you will definitely compromise on comfort. You must either choose comfort or image .. [/ QUOTE]
My friend, I am using the bow I mentioned above. (eibach prokit 3cm) I had no loss of comfort. because;
these prokit springs are the original factory outlet springs of the vehicle in Europe. The difference from our vehicles is that it is 3 cm lower because the roads and conditions are more convenient. Most of the time, when a new model comes out, when we see the pictures in newspapers and magazines, the vehicle is very attractive to us because it has a 3 cm lower spring than ours, despite the original rim on the vehicle.
The springs that miss the comfort of the vehicle and shake are 50-55 and 60 mm springs.
maximus 2011-08-26 02:25:12
08.05.2020 16:03 # 14
[QUOTE = HuseyinTurk] My proud car is next to yours, my vehicle is officially crawling on the ground, look at yours, I have documents on the pictures:) [/ QUOTE]
Hüseyin On My Eye ... Stay Informed ... GülmeSırıtma
You Are Not Human ... You are an Angel, You are Hüseyin; Sırıtma
Don't come to Davos again ...
08.05.2020 16:03 # 15
hakann83
If you download it, it is my opinion that when two people get on the back,
08.05.2020 16:03 # 16
I do not think that rubbing will be done because the tire diameter is the same as the original (from the center to the tire century).
08.05.2020 16:03 # 17
[QUOTE = MaximuS] If you have decided to lower the tool [QUOTE = eren8er], you will definitely compromise that comfort .. you must choose either comfort or image ..
Brother, if I cut the original springs from very little ends, would I have too much comfort to try?
08.05.2020 16:03 # 18
Muhammet CAKIR
short cut brothers you cut short 70 - 80 tlye you find very comfortable already cutting heating is not more important than disability work life
08.05.2020 16:03 # 19
I looked at 400tl or something, I think I can not find the eicbag for 70 80 lira.
08.05.2020 16:03 # 20
Muhammet CAKIR
[QUOTE = HuseyinTurk] I looked at 400tl or something, I think I can not find the eicbag for 70 80 lira prices? If you are looking for comfort, you should get a sports shock absorber together with the bow :)
Page : / 2
