How do I decompose the metal sound in the back
08.05.2020 19:43 # 1
baya1994
There is nothing on the road in 1.4 hdi vehicle. There is no problem when passing through the guns, but if I entered the hole or patched the road, it sounded like a metal knock from the back, I put a sumger in the metal part of my seats. I said from the spare tire, I screwed the screw in there, I even took out the jack inside, and hit the same thing again, as if I am rubbing the tailgate with my hand, no play, this is the problem.
I put a diaper where the luggage tongue is, to keep the tongue well, but there is still a problem. It sounds very bad, it is not creak. as if you were hitting an iron.
08.05.2020 19:43 # 2
Omer_mydnc
Hello, the bakelite clips that protect the rear wiper arm are making noise because they get dirty over time. Omer_mydnc 2016-03-22 23:09:32
08.05.2020 19:43 # 3
baya1994
If the pilastic between the glass and the wiper outside is intact, I looked at it first, I even removed the wiper or something like sarpiya glass, but again the same thing is worth it but I don't understand. Of course there are people who know my solution here
08.05.2020 19:43 # 4
samet206
No problem with the rear team, if not, other places that come to my mind, the tailgate lock counter, the spare wheel cage, the silencer, something else that I can not think of, can do unnecessary sound in the back.
08.05.2020 19:43 # 5
Omer_mydnc
I was wrong, the clips of the plug-in bakelite inside the boot that protects the rear wiper motor may have been removed.
08.05.2020 19:43 # 6
ssakyel
Where exactly does it come from behind? It is more or less obvious from the trunk or the undercarriage.
08.05.2020 19:43 # 7
outlaw
stop rear torsion
08.05.2020 19:43 # 8
baya1994
If it comes from torsion, it makes it squeak but this sounds like it is as if the rear trunk lid is urgently closing and closing hard every time I enter it, but of course it does not hurt. I got the car one week ago exper ten, and the back shock absorbers said to me, this sound comes from somewhere else.
08.05.2020 19:43 # 9
KILIC
Try it like this, if someone sits in the trunk, hold the trunk lid, try to go through a hump, if it comes again, it is not related to the trunk lid, but if the trunk lock mechanism is too far back, the trunk lid may be rubbing into the bonnet when the vehicle is flexing, or if the lock is too far ahead, the trunk lid may be rubbing into the bonnet or may make a sound because the trunk is not fully closed.
08.05.2020 19:43 # 10
baya1994
Which one is the lock mechanism?
08.05.2020 19:43 # 11
KILIC
The screws may be loose. Picture 307 is the same, but 206 is not the only plastic container.
SWORD 2016-03-23 14:54:43
08.05.2020 19:43 # 12
baya1994
what is the logic of this, so how do i adjust it in the simplest way today i drove back to the car definitely comes from the tailgate
08.05.2020 19:43 # 13
KILIC
Did you hurt the tailgate?
08.05.2020 19:43 # 14
baya1994
Somebody held the door in the morning, I drove again, there was a sound on the right and there are shoes on the left side, I prevented them from knocking them off and the problem was solved only by the wheel
08.05.2020 19:43 # 15
KILIC
[QUOTE = baya1994] someone in the morning held the door, I drove again, there was a sound, there were shoes on the right and on the left side, I prevent them from knocking them off and the problem is solved only by the wheel
I'm glad you're resolved.
