How do I connect the speakers on the 206 cc door to the tape?
08.05.2020 17:35 # 1
EErgul
hi
I think the rear speakers of my cc are working and the speakers on the door are not connected. That was when I got the car. the tape was not original (still the same tape) most likely the ones on the doors were not connected while the tape was changing. Is there any chance that this tape does not support the speakers on the door? If not, how can I connect something simple? I checked it with a flashlight and the speakers on the door are very thankful in place:) & nbsp;
08.05.2020 17:35 # 2
EErgul
[QUOTE = 307bursa] Do you have the cable of the speakers coming there?
if it is coming, when you connect it to the outputs of the tape, it should work directly, if it does not work, it may break out & nbsp; It is not possible to support it.
08.05.2020 17:35 # 3
Alicilik
[QUOTE = EErgul] hello
I think the rear speakers of my cc are working and the speakers in the door are not connected. That was when I got the car. the tape was not original (still the same tape) most likely the ones on the doors were not connected while the tape was changing. Is there any chance that this tape does not support the speakers on the door? If not, how can I connect something simple? I checked it with a flashlight, the speakers on the door are very thankful in place:) & nbsp;
There is no situation where the tape is not connected to the speaker. The tape has two sockets. One is the output of the speakers, the other provides the electrical and control cables. Whatever tape you plug in, the speakers should work when you plug in the appropriate socket.
Were there any amps when you bought them?
Belk` tape from the amplifier may have been drawn from the RCa and the line from the amplifier may have been drawn from the speakers. If so, the audio cable from the tape is not connected. The door must be removed and looked after. If you do not know, do not get infected, even if you go to an electrician, the opponent can say what is going on. Reviews
08.05.2020 17:35 # 4
EErgul
[QUOTE = Receiving] [QUOTE = EErgul] hello
I think my cc's rear speakers are working and the speakers on the door are not connected. That was when I got the car. the tape was not original (still the same tape) most likely the ones on the doors were not connected while the tape was changing. Is there any chance that this tape does not support the speakers on the door? If not, how can I connect something simple? I checked it with a flashlight, the speakers on the door are very thankful in place:) & nbsp;
eyv we will go to the electrician then but my fear is that when he disassembles the door trims, it seems like they break a few nails, nobody cares like his own property
