How do I clean the antifreeze flowing into the mop ...
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:02 # 1
emresensoy307
Friends, I think the bottom of the car mat is wet, antifreeze honey is pierced.
08.05.2020 19:02 # 2
monalos
Did you change the honey, there is a flow in me, can you tell me how they changed? What was the cost?
08.05.2020 19:02 # 3
emresensoy307
There was a problem in my thermostat, we put antifreeze. After about a month, I noticed that the bottom of the driver's mat was wet, I went to the service and the antifreeze was faded from any part of the honeycomb.
08.05.2020 19:02 # 4
monalos
350 ml, I looked at the pejo market, the original 140 supplier industry was 50 TL
08.05.2020 19:02 # 5
emresensoy307
I did not look at the market, I have to go to the emergency service so I have to go to the authorized service.
08.05.2020 19:02 # 6
monalos
OK, I looked for 206 and I
08.05.2020 19:02 # 7
emresensoy307
Guncel ...
08.05.2020 19:02 # 8
gungor
Put a lot of cardboard, I changed it quite a bit
08.05.2020 19:03 # 9
samet206
First of all, you will remove the mop in the wetted part. If the mop is not worthwhile, replace it, the carpet has damaged the mop anyway, probably, my carpet mat has been thinned, because anyway, even the vacuum cleaners in the gas to dry the floor carpet will work for the area in order to ventilate the cardboard newspaper. make regular changes.
08.05.2020 19:03 # 10
emresensoy307
Just as I always put towel paper, I press it with my feet, it absorbs antifreeze, we wash it, remove the mop, the flooring can be dust, it is important.
08.05.2020 19:03 # 11
106fb
The same incident happened to me too. I have been trying to dry it for 1 month. Now it is still damp.
08.05.2020 19:03 # 12
Sertan
It is a recent incident in me. Water leaking from the honeycombs wetted the carpet completely. I took it to the washer, squeezed the foam first and then pulled it with a broom. Then he put the 30-40 pound foot heater we know. He was in the washer for about 10-12 hours and was dry when I bought the car. I looked at it in the morning, there was still humidity and I left it for another day. Now there is no wetness and odor.
08.05.2020 19:03 # 13
bayenglisher
My dear friend, that problem was at my 307. It dissolves to 80 TL. There is no need to change the honeycomb generally. Just sticking.
