How do I change the 206 screen with pictures
08.05.2020 15:26 # 1
106_arts
friends 206 on my car screen only have clock tape information etc. no
Bikac was selling friends on the site, is it easy to wear it if I buy it from them? ekran
08.05.2020 15:26 # 2
tigerland
Grasp the place where the screen is towards you, you will see that there are teeth on the edges of the check cover without loading too much. It is mounted on the screen with 2 screws. the socket has a tab, you lift it counterclockwise. then you unscrew it in the socket :) simple operation but gently without distraction :)
08.05.2020 15:26 # 3
qqyyxx
[QUOTE = 106_arts] friends 206 on my car screen there is only clock, tape information etc. no
If you want to change the screen of this vehicle, I know that the trial will not be available for this vehicle.
08.05.2020 15:26 # 4
Ozgur
Unfortunately, yours don't fit the vehicle.
no trials, you will be wasted.
08.05.2020 15:26 # 5
toprakk
Not like your friend said. The information screen you said is big. The cover we will mount is also small in place. you will get a cover, you will get a screen. What information will you expect from the tool. and you have already changed your tape. other information gasoline internal heat external heat how much mileage information you need to have extra software. plug in the screen so forget all the information wersin event. rather, forget this screen magnification event. sell this tool from the model with a large screen :)
08.05.2020 15:26 # 6
tigerland
how many models of this vehicle I see for the first time, this way only writes the clock, it does not fit in vain don't take it, even though the cover is already required com2000
08.05.2020 15:26 # 7
Ozgur
com2000 is required.
The infrastructure of the vehicle is not compatible for two trip computers and the screen.
no way.
08.05.2020 15:26 # 8
106_arts
this car is 2002 model 1.6 16v 110 hp this car has original tape cd player and screen on tape
so they put it on tape in this vehicle
