How do I activate the headlight sensor?
08.05.2020 17:56 # 1
Thomassee
Guys, I had the heads of the battery removed.
Now the headlight sensor is not working Big smile
I think he went away when he removed the battery.
How can I run this again ??
I can't try it right now, but it seems the same in the rain.
08.05.2020 17:56 # 2
Alicilik
I have not had a 206 with headlight sensor but with all the information I have pushed: d
Press and hold the end of the signal lever while the ignition is on, and the screen will sound as if it beeps.
08.05.2020 17:56 # 3
Turn the ignition on halfway, just turn on the battery lamp, then it will open when you hold down the turn signal lever.
08.05.2020 17:56 # 4
Thomassee
Thanks, I tried.
For example, I was wondering, it is activated, does it turn off when you do more ??
Also, I can't try the rain sensor, but there is no push button on the edge.
I wonder how can I activate it?
Thanks.
08.05.2020 17:56 # 5
Alicilik
[QUOTE = Thomasse]
Thanks, I tried.
Thanks.
Yes, you will be deactivated again.
I guess you need to get it to auto for rain. The wiper puller should be auto there.
