how do doors open
08.05.2020 16:59 # 1
komando
hello i wrote yesterday but i couldn't find my message :) my car did not open with remote control i wanted to insert key and open it again did not open again i would be glad if you helped i changed the battery of the control for about 25 days car never worked ..307 xt 2.0 hdi 2002 model
08.05.2020 16:59 # 2
brutal
I can't help thinking that there is a malfunction in the vehicle's central locking system.
08.05.2020 16:59 # 3
komando
I don't think it was new in terms of maintenance. It didn't work for about 15 or 20 days. I think the battery is dead. But how do I open the doors?
08.05.2020 16:59 # 4
The key needs to open the doors manually. Try squeezing the WD-40 from the keyhole to the inside. Reviews
08.05.2020 16:59 # 5
komando
I tried but it did not turn the key only to the locking side, not to the opening side & nbsp;
08.05.2020 16:59 # 6
gozem
As an alternative, you will find a body shop and unlock the bonnet from the appropriate barrier. try to turn on the remote after connecting the new battery, I don't know how good it is, but you have to try it ..
08.05.2020 16:59 # 7
Polon
The same thing happened to me on the commando. The doors remained locked in the closed garage. The key did not open manually. I tried the foot for about 3-4 days but in the end I found a competent key unlocking. But they did it. With the tools in their hands, they lightly swept from the top corner and placed the air bags. Then they inflated them and brought the key to the contact with a hard wire & nbsp; and opened the contact. Then they pressed the glass button with another wire and then opened the window. Then I opened the door from the inside handle. and introduced the key again from the ignition of the car. The problem has been solved in this way. Whether the battery is running out or not, it can be measured with a measuring instrument by cutting a & nbsp; + pole cable under the vehicle. This is probably because your door lock is either defective or not used too much. In this way, I would have it made for such cases and open the doors manually once in a while. I hope & nbsp; I was able to help.
By the way I am 50 TL to the keymaker. 30 TL in the industry. I made it. Get your information.
08.05.2020 16:59 # 8
komando
they are all beautiful but who can I trust? I do it with my own means, but I am working in now. I called the service, the room is from the battery.
08.05.2020 16:59 # 9
Serkan
Hodja, first find out the price of the front butterfly glass, if it is cheap, break the glass and open the door
08.05.2020 16:59 # 10
[QUOTE = Serco05] Teacher first find out the price of the front butterfly glass. "0" alt = "Smile" title = "Smile" /> At least that's it here.
koliva 2012-08-16 17:19:42
08.05.2020 16:59 # 11
Alicilik
[QUOTE = Serco05] Teacher first find out the price of the front butterfly glass, if it is cheap, break the glass and open it from the inside [/ QUOTE]
I saw 488tl in the servicebox, I hope I saw it wrong. "0" alt = "LOL" title = "LOL" />
08.05.2020 16:59 # 12
Serkan
Normal auto glazers wear between 60-80 TL, but I do not know if I can find it with friends.
08.05.2020 16:59 # 13
ekinali
Can I ask you something? How can I open our car peugeot 301 engine hood? There is no problem with the key, but I do not know where to say & nbsp;
08.05.2020 16:59 # 14
ekinali
I wonder how can you open the bonnet my car peugeout 301 & nbsp;
there is no problem with the key & nbsp;
08.05.2020 16:59 # 15
cnrx9004
my friend had e 36 the battery is not open the center does not open the key does not even open manually, we forced the hood, we reached the hood wire a little later, we pulled it opened but I think where the wire of 301 should look, I think it is the most logical engine hood, I think how to open it with the least damage to the hood.
