|   | How can the Peugeot 206 defrost the windows? |
| 02.12.2022 00:00 | # 1 |
|  Mesutaslan | |
| /div> Friends, I start the car as in the link above and drive like this. After a while the windows fog up. I tried multiple variations but it didn't work. I want to solve the misting together with the engine temperature and not waste fuel. How can I do that.  | |
| 02.12.2022 07:15 | # 2 |
|  batukerim | |
If you hit the windows in a hot position with the air flow from outside to inside, there will be no fogging, I haven't had them for years.
| 04.12.2022 00:18 | # 3 |
|  talip206 | |
| You have the circulation inside, so it makes more condensation. If you pull it to the left, the air enters from the outside. If the condensation persists despite this, check the heating system. Is there any wetting etc. on the carpet? | |
| 05.12.2022 15:02 | # 4 |
|  antipollution | |
Just like taking the air from the outside, you can turn it in when you approach the traffic or the truck, or turn it off for a while and start it again when the traffic opens. But despite all this, it can still be foggy. In this, if you clean the windows from inside with Cif `li water and a cloth, if you do this every 2 months, it is effective to prevent condensation. In particular, cif has such an effect. | |
