how can i upgrade my car
08.05.2020 17:30 # 1
206 ersan
friends how can i upgrade my car low six 206 sw
08.05.2020 17:30 # 2
Are the roads in your area too bad?
08.05.2020 17:30 # 3
ekinoks44
I have the same problem, especially when I go to the village or something, I sometimes rub under the car, sometimes it is not suitable for our roads, low vehicles ..
08.05.2020 17:30 # 4
Bugra
I think it would not be healthy to upgrade your vehicle's front and rear parts as original. But if the owner before you wore a sports bow or cut the springs and played with the back torsions, you can take the original springs and turn them back to the original.
08.05.2020 17:30 # 5
206 ersan
my car 206 sw compared to the normal 206 s front and rear & nbsp; tire spacing a little longer and I think it would be okay if i raise the previous owner 4 or 5 cm when I pass the bumps when 5 people or so bide the shock absorbers are very hard very hard v It can be said that it is hard or even it does not stretch. Gaseous shock absorbers are gas shortened or gas is tight.
08.05.2020 17:30 # 6
ahmet_bjk
I can't go over the 2.5 liter empty coke bottle with my vehicle, it's too low
08.05.2020 17:30 # 7
GokhaN
[QUOTE = 206 ersan] my car 206 sw compared to the normal 206 s front and rear & nbsp; the tire spacing is a little longer, and I think it would not be a problem if I raise the owner before me when I go through the bumps when 5 or so, if I raise 4 or 5 cm Bidet shock absorbers are very hard, very hard, v hard, or not even flexible. If you change it, the problem may improve. If you can put a picture, let's say something clear.
08.05.2020 17:30 # 8
mstf shn
IF THERE IS A DIFFERENCE THERE IS A DIFFERENCE FROM THE FACTORY DIMENSIONS TO COMPARE YOUR OWN VEHICLE ...
