How can I make 206 rear windows auto
08.05.2020 17:47 # 1
206 ersan
friends 206 full house rear windows side mirrors or something is not automatic mine how can i do how many people do you have experience
08.05.2020 17:47 # 2
ufuk91
As you say in my vehicle. I don't think you can turn the rear windows into automatic, so at least it's not worth the effort, the cables that will be attached to the windows with glass lifting motors, the new buttons that will be pulled to the buttons, the back of the middle hand brake will be cut and mounted. As I said, even if it is done, it does not stand at all, it is not worth your effort or your expenses.
As for the mirrors, the roland garros originally have automatic folding mirrors, but before I bought those mirrors were broken and replaced with normal electrics so the settings are electric but not folded. It will be very difficult with similar operations in converting to electric mirror, I do not think it will be worth the expense and effort.
Is it impossible, I don't think so what people are doing. But I don't think it's worth the effort + expense / results index
08.05.2020 17:47 # 3
EErgul
it becomes salty. not done. I think it is no different from the original. If the section behind your hand brake is not different, you can cut the keys from the full ones and mount the keys there. you pull a cable to the keys. You also attach your engine to the windows.
the real trouble is how do you adjust the flooring on the door after making it automatic. the hole of the glass opening arm will remain there. I feel like there is a little bit to get away from originality. I think there is no need to cancel the rear windows completely, it makes more sense :)
08.05.2020 17:47 # 4
Alicilik
You have to remove the installation from the glass doors with electric back. Or the part must be provided by service or particle.
08.05.2020 17:47 # 5
error
Why not with the necessary engine and control elements and an electrician who does not run away ...
but I recommend you to get the equipment from the publishers ...
08.05.2020 17:47 # 6
EmreOz
I don't know much about the subject but I think it can be done .. I need a solid master .. but it will be salty :)
08.05.2020 17:47 # 7
ErolSs
brother, I had the subject on the same subject, the rear window automat was taking the whole system to 100 TL, but since I could not find a patient master who needs to get sick, I did not buy the bidet electrical system as it should be overhauled again.
08.05.2020 17:47 # 8
Aziz
I think it's good, but its cost changes when it comes in. I have mentioned about a subject before, unnecessary expense, I buy 1 ice cream sitting on the back, it turns on and off :)
08.05.2020 17:47 # 9
[QUOTE = Aziz] I think it's good, but it changes when the cost comes into play. I have already mentioned something about it, unnecessary expense, I buy 1 ice cream on the back of the person turns on and off:) [/ QUOTE]
Clap
