How can I fix 508 front bumper underlined
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
24.06.2020 08:46 # 1
Kawuniichii
Hello guys, I rubbed the left front part of my 508 front bumper on the curb the other day and the lower plastic part was also scratched, not too deep, but nauseous, when you look carefully, how do you suggest a solution to reduce the scratch at least? The paint color is atomic gray, sometimes referred to as smoked. I thought if I put a little sandpaper with the finest sandpaper and then put a paste on it, would the scratch be reduced, is it true or would the paint be ruined by the sandpaper?
24.06.2020 15:25 # 2
If you do sandpaper, it is necessary to see whether paint or water sanding can be done. It would be better to help if you upload photos from www.fastresim.com.
24.06.2020 16:50 # 3
Kawuniichii
This is my beginner :) com / H7eQ4Vhttps: //hizliresim.com/o3sX6FCidden they are nauseous
24.06.2020 16:52 # 4
Kawuniichii
By the way, Soner Bey, I noticed that there is something hanging from the bottom of the car, I think it was then that he had hit the gold in the barrel in the last months. : ((((Correction: it seems that the plastic bumper part: Dddd was an eye mistake I guess :)) Kawuniichii2020-06-24 16:54:01
25.06.2020 08:58 # 5
Take my teacher, the plastic enclosures look like they are broken, of course, you have to bend down and look, that's easy. When it comes to the bumper, the white parts on the fog lamp can be removed with cake, the bottom part is painted up to the plasticine and thoroughly cleaned and the remaining part can be polished. If you can, you can sand as you said and apply primer first with plastic primer spray paint. Then you can spray paint according to the paint code of the vehicle, of course, some attention is required.
