How can I change the headlights?
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:49 # 1
reality59
I want to disassemble and black out completely, but it holds 4 screws. I found 3 of them. Does anyone knows ? can you help?
08.05.2020 16:49 # 2
[QUOTE = reality59] I want to disassemble and black out completely, but it holds 4 screws, I found 3, I removed and I did not find 1. Does anyone knows ? can you help? [/ QUOTE]
I once wrote an article for this. You will see the screw when you look down at the top of the hoods. Did you remove them? Where are the screws you find?
08.05.2020 16:49 # 3
maestro
http://forum.peugeotturkey.com/forum_posts.asp?tıd=7902&title=307-n-tampon-ve-kuaklarn-skl the
08.05.2020 16:49 # 4
reality59
thank you for your health.
08.05.2020 16:49 # 5
reality59
[QUOTE = koliva] [QUOTE = reality59] I want to disassemble and black out completely, but it holds 4 screws, I found 3, I removed 1 I could not find. Does anyone knows ? can you help? [/ QUOTE]
I once wrote an article for this. You will see the screw when you look down at the top of the hoods. Did you remove them? Where are the screws you found?
I removed the screws in this picture, there is one above (not the number 4 screw) I disassembled it, 2 then it is below, there is the number 3, I disassembled it inside, I did not try to remove it tomorrow in the light of day, I will try to disassemble it. It looks very bad, let me clean it while it is ready.
08.05.2020 16:49 # 6
metin
There is a bolt at the junction of the bumper and the fender, and when it is removed, the bumper holds 2 nails. If you recover from them, the bumper will come down. & nbsp;
Since one bolt of the headlight is under the bumper, you need to remove the bumper.
08.05.2020 16:49 # 7
reality59
Is that screw you mentioned in the pictures?
08.05.2020 16:49 # 8
[QUOTE = reality59] Is that screw you mentioned in the pictures? [/ QUOTE]
What do you need for the picture. Text made recipe delivered to the address.
Look, you will see the tire immediately from there "Smile"
Let me tell you about it. Get out of your vehicle, with the face facing the other ten wheels next to the ten wheels. Have one foot full of studs and the other one under the headlight. Then, just as you are, put it on the floor and look inside the hood. You will see the screw where the ten buffers come "Smile"
08.05.2020 16:49 # 9
reality59
[QUOTE = koliva] [QUOTE = reality59] Is the screw you mentioned mentioned in the pictures? [/ QUOTE]
What is the need for the picture. Text made recipe delivered to the address.
Let me tell you about it. Get out of your vehicle, with the face facing the other ten wheels next to the ten wheels. Have one foot full of studs and the other one under the headlight. Then, just as you are, put it on the floor and look inside the hood. You will see the screw where ten buffers come from "Smile"
OK. thank you. I hope I will try again tomorrow. I hope.
08.05.2020 16:49 # 10
metin
koliva abi I found your picture (:
This painting is the bumper removed. The bolt between the headlight and the water tank is the headlight bolt under the bumper. & nbsp;
The thin channel under the fender is the place where the bumper enters.
After removing the bolt after removing the bolt from the inside with a flat screwdriver, the bumper will come out. & nbsp;
those two nails, just below the fender in the picture is happening on the thin channel.
08.05.2020 16:49 # 11
metin
Those nails are in the front of the tire when the car is stuck from the bottom, where the bumper and the fender meet, the area marked by two circles.
08.05.2020 16:49 # 12
reality59
The above picture is very useful to me. Thank you very much. It is necessary to download the buffer first to remove the FAR. & Nbsp;
08.05.2020 16:49 # 13
metin
[QUOTE = reality59] the picture above will help me a lot, thank you very much. It is necessary to download the buffer first to remove the FAR. & Nbsp; [/ QUOTE]
Yes. Even when installing the headlight, do not think about the bolt under the bumper, then do not think that it is not necessary to remove the bumper when removing the headlight. Because even if you disassemble all the bolts, you cannot remove the headlight because the sides of the headlight are attached to the bumper unless the bumper is removed.
08.05.2020 16:49 # 14
[QUOTE = text]
This painter is the bumper removed. The bolt between the headlight and the water tank is the bolt of the headlight below the bumper. . & nbsp;
The thin channel under the fender is the place where the bumper enters. div>
After removing the bolt, the bumper will come out when it saves the two nails with a flat screwdriver from the inside. & nbsp;
those two nails is in the thin channel just below the fender in the picture. src = "smileys / smiley36.gif" border = "0" alt = "LOL" title = "LOL" /> That umbrella you see at the back is still standing there. It doesn't feel like air, let's be protected from the sun under it. img src = "smileys / smiley1.gif" border = "0" a lt = "Smile" title = "Smile" />
08.05.2020 16:49 # 15
metin
[QUOTE = koliva] [QUOTE = text]
koliva brother found your picture (:
This painter is the bumper removed. The bolt between the headlight and the water tank, under the bumper is the bolt of the headlight. & nbsp;
The thin channel under the fender is where the bumper enters.
After removing the bolt, the bumper will come out when it saves the two tabs with a flat screwdriver from the inside. & nbsp;
< div> those two quotes are in the thin channel just under the fender in the picture. Hanaaa my car "LOL" That umbrella you see at the back is still standing there. the break is going well but
Maybe it is already certain that the sun comes out (: When it is closed air, the psychology of the human turns upside down.
08.05.2020 16:49 # 16
[QUOTE = text]
Perhaps the sun is set out to come out already (: Whenever there is always indoor air, the psychology of the person will be turned upside down.
It is so. There is a person who has a lot of psychological support. Summer is still good, but the weather is a little bit open, but you are getting up in the morning, the weather is dark, the evening is coming home, the weather is dark "Smile"
08.05.2020 16:49 # 17
reality59
I removed the bumper, but I couldn't turn on the headlights, just put it back in the bumper (finished at 01:43.)
08.05.2020 16:49 # 18
toga406
Is it the same in 406?
08.05.2020 16:49 # 19
reality59
I have no idea, I would have said this until I removed the bumper. A few people had already said what I said, but the owner of the car before me screwed the bumper back from its separate parts, I removed them and fastened them with clips.
08.05.2020 16:49 # 20
toga406
Hmm, I'm confused even when I see yours. hard work I think those who disassemble can get damaged while disassembling, right?
Page : / 2
