How about this system?
08.05.2020 14:09 # 1
mabolla
Hello to everyone
With what I learned from the forum and what I knew more or less, I designed to make a system like this for me.
-JBL 75.4 amplifier (4 channels)
- JBL GTO 507 ce 13cm component (back)
JBL GT5- 650 C 16cm component (front)
-JBL CS1214 1000W JBL Bass (30 cm)
I am thinking of using the original tape of the vehicle, maybe I can change it in the future.
Whatever you say, I have a few more questions as you comment. I believe I will handle this issue.
08.05.2020 14:09 # 2
mabolla
no sound from anyone :)
08.05.2020 14:09 # 3
GokhaN
unfortunately, not everyone understands the sound system Gülme but my advice is that the amp is a good choice, but if you don't choose better quality brands in the mid, bass will always drown the sound in the mid.
08.05.2020 14:09 # 4
mabolla
Well, I don't really understand either :) Which brand can you recommend ..
08.05.2020 14:09 # 5
Kifanhom
I like listening to music with low noise but high quality
I do not know which amp fits with which bass but I have edison 5 + 1 amp, I have her 30 cm hertz bass, I have 300 watt oval pioneer columns
I listen to good quality music with original front door pillars and original mirror tweeters.
08.05.2020 14:09 # 6
mabolla
ok i think just like you, i did live music with very good stage systems for many years, then my car's system does not satisfy me in terms of quality. i want to do something like you frankly. how much did you cost that system dude
08.05.2020 14:09 # 7
H-a-d-i
[QUOTE = mabolla] hello everyone
I think of using the original tape of the vehicle, maybe I can change it in the future.
Obviously, it seems difficult to buy this system at this price, if you can, I think it will satisfy you.
I know the voice of the mentioned mid suits. I think it's good quality. Noticeably different sounds cannot be expected from the stomachs you will give and receive more money.
I think it should be an amp bass output. It should also be considered that the system will be revised in the future. I recommend Edison 505 (4 + 1 output) model or JBL 755.6 (4 + 2) output) in Kifanhom. The 75.4 model is not a suitable amplifier for connecting bass and mid team.
If you are going to use the original tape, the converter you mentioned should be connected. It has a price of 25 TL. but if I were you, I would buy the Pioneer 2150 for 180 TL. this model prints the original pejo tape. there is as much difference as the mountains.
is the comment sufficient?
h_307 2010-02-01 01:11:08
08.05.2020 14:09 # 8
mabolla
thanks for comment look, i didn't know that i learned i know i mean i dont connect both of them i guess it doesn't make any sense.
08.05.2020 14:09 # 9
H-a-d-i
Of course, both bass and mid can be connected to 75.4. but when he opens the settings to get the bass sound, the sound will drown in the mid suits.
but if the bass is output, you can decrease the bass setting of the mid and increase the bass setting of the woofer. because the bass settings of the woofer and mid can be made with different buttons.
08.05.2020 14:09 # 10
H-a-d-i
is this the bass you will get
h_307 2010-02-01 01:43:05
08.05.2020 14:09 # 11
mabolla
Well, if my friend is only comp in the front, I would need 5 channels at that time.
by the way, for the information you really gave thanks
08.05.2020 14:09 # 12
mabolla
yeah bbass its the same
08.05.2020 14:09 # 13
H-a-d-i
[QUOTE = mabolla] yes bbass it's the same [/ QUOTE]
This bass model is old. I think the budget can be increased a little and a stronger bass can be taken. See RMS values in bass. Not less than 300W. I recommend the pioneer 308 D4 model.
It's not about connecting or connecting to the back, hodja. the thing is, an ordinary 4-channel amphitheater is not very nice both bass and mid team. Although it satisfies you in the first place, you are likely to regret it in the future and change it.
08.05.2020 14:09 # 14
mabolla
I understand better now, if I am already going to do this job, I am in trouble.
like how is a bass like this
http://urun.gittigidiyor.com/pıoneertsw-308d4-1400watt-hemde-kabınlı_w0qqidzz23496948
08.05.2020 14:09 # 15
H-a-d-i
[QUOTE = Mabolla]
I understand better now, if I'm already going to do this job, I'm in trouble.
http://urun.gittigidiyor.com/PIONEERTSW-308D4-1400WATT-HEMDE-KABINLI_W0QQidZZ23496948 [/ QUOTE]
this is the product I'm talking about. The price of bass in Istanbul is 125 TL. cabin 40 TL.
08.05.2020 14:09 # 16
mabolla
Well, when I decided to set up the system, for example, do you have the opportunity to help me in the supply of this product?
Well let's say bass pionerr, anfi de edison 5 channels. So is there any need to change mid teams :)
08.05.2020 14:09 # 17
H-a-d-i
http://www.sahibinden.com/search.php?b%5bspecial_type%5d=&b%5bpromo_hpva%5d=&b%5bpromo_fdva%5d=&b%5bpromo_chva%5d=&b%5bpromo_hpsa%5d=&b%5bpromo_spva%5d= & b 5ball%% 5D = & b% 5bsearch_text% 5D = 308 + D4 & c = 0 & search_result_page_limit = 20 & b% 5bcountry_id% 5D = 1 & b 5bcity_id%% 5D = 0 & b% 5blrt% 5D = 1 & b% 5blocation_dat% by 5D = & b 5bregion_id%% 5D = 0 & b% 5btown_id% 5D% 5B% 5D = 0 & b% 5bdistrict_id% 5D% 5B% 5D = 0 & b% 5buncompleted% 5D = 0 & b% 5bminpri% by 5D = & b% 5bmaxpri% by 5D = & b 5bpricecur%% 5D = 1 & b 5bilantarih%% 5D = & b% 5bdate_typ to 5D% = h_307 2010-02-01 02:04:04
08.05.2020 14:09 # 18
H-a-d-i
[QUOTE = mabolla] Well, when I decided to install the system, for example, do you have the opportunity to help me in the provision of this product?
I will do whatever I can. I buy it for you, I give PTT cargo.
If the budget is limited, you can hang out with the original speaker on the doors. you will get it later JBL miler. If you don't connect the 308D4 and 2 woofers in the future, the Edison 505A will do its job well. Edison 505A is around 250 TL, I think.
h_307 2010-02-01 02:11:02
08.05.2020 14:09 # 19
coyote26
I agree with our moderator .... you can not taste much of the original tape. I recommend pioneer or alpine ... you can use soundmagus or cadence as bass ... I had 300 rms 30cm soundmagus. I use ...
08.05.2020 14:09 # 20
GokhaN
I suggest infinity in mid teams. I'm thinking of using infinity in my new vehicle. & nbsp;
Page : / 2
