Hour
08.05.2020 21:17 # 1
Never up
Why does the clock of the car change? No pole disassembly is not an attachment, this is a sign of an electronic malfunction. Where should I have it checked?
08.05.2020 21:17 # 2
talip206
As long as the pole does not come off, the clock cannot reset. If there is a post-add alarm tape etc. it can do so. If they pull the electricity to the watch from elsewhere, when the car goes into eco mode, it cuts off the electricity of the watch and resets the room.
08.05.2020 21:17 # 3
Never up
thanks it was very informative. The sound system and tape were probably pulled. I don't think it has a polar head because if it had a polar head, it would reset itself on tape. Probably what you said was the tape or system. So does this cause me any other electronic problems?
08.05.2020 21:17 # 4
talip206
It does not cause any problems, but it is annoying. I think you can see and correct the place that does it. When you switch to eco mode, take the power of the watch from where the electricity is not cut. talip206 2019-08-07 19:48:29
