Horsepower and Torque drop
08.05.2020 18:04 # 1
capello
Why does
At 112 thousand km, a diesel vehicle horsepower is 90 tons and 150 is output.
Is the engine dead.
08.05.2020 18:04 # 2
capello
1.6hdi 407 here.
as far as i know 110 hp 250 torque
08.05.2020 18:04 # 3
alp2525
I have the same vehicle in me, I have never had a test or something, is my 105000 vehicle in me or is it low ???
08.05.2020 18:04 # 4
capello
No 110 writes, but he has no more.
08.05.2020 18:04 # 5
capello
no blowing, no oil reduction, no excess fuel
the masters say drive, I don't understand
08.05.2020 18:04 # 6
VLKNYKSLN
I think show the car to the authorized service first and then I put it on dyno to make sure.
08.05.2020 18:04 # 7
capello
what you call dyno is not what they do by inserting those front tires
89 horsepower from it
08.05.2020 18:04 # 8
capello
Does the volant egr and pressure pad make so much difference
08.05.2020 18:04 # 9
samet206
As simple as everyone knows, the pressure on the speed increase affects the pad, but I do not know if this is reflected in the engine's horsepower and torque.
08.05.2020 18:04 # 10
capello
There is an insurmountable situation in question. I think of everything, including selling the car
08.05.2020 18:04 # 11
alp2525
How many speeds at 3000 rpm should he show 130-135
08.05.2020 18:04 # 12
alp2525
in 5.vites
08.05.2020 18:04 # 13
hsnsnl
Did my teacher press and burn in 1st gear, and when you go ahead and put the vehicle in 2nd gear, did you press or force? If it does not come out unconsciously if it is ticking and gathering, there is a problem with the turbo of the vehicle ..
08.05.2020 18:04 # 14
capello
I remember him as an approximate figure for how long I had no opportunity to go to such a speed but
08.05.2020 18:04 # 15
capello
If I get up fast in 1st gear, it burns esp. I don't know.
08.05.2020 18:04 # 16
wlkn87
I wrote to my friend specially, it happened to me 1 month ago, the pressure was missing the pad, but it was not an exaggeration seriously, the performance of the car was very bad, I thought that it was a bad luck until I realized that I missed it (the engine came to my mind that the exhaust blew the engine went off). I did not want to go to the car with exploration in the master, the last pressure is the pad, I was pushing, the flywheel has not changed officially.
08.05.2020 18:04 # 17
capello
Well, does this pressure cause the horsepower to be low in horsepower and torque?
08.05.2020 18:04 # 18
hsnsnl
Well, according to my opinion, it is caused by the fact that the vehicle pad ends in the km without using the vehicle too much. 5.vıtes 110km speed 2500rpm in my car .. 4.vıtes 77km speed will be 2100 or 2200rpm
08.05.2020 18:04 # 19
capello
I don't know how long it has been, I just got used to diesel.
my concern is this dyno data. Does it fix this when the pressure is changed on the lining
Maybe the depollution not knowing the fault might be causing this miscarriage
08.05.2020 18:04 # 20
hsnsnl
you need to see why it gives the error, you need a pc connection .. is it observing whether the speed of the print pad is doing the km speed in the gear values.
Page : / 2
