horn problem and turbo hose
08.05.2020 20:06 # 1
AllyDrago
good morning - hello. my horn works hard ... there is nothing in the electrical parts. I can even summarize what the problem is. When you load it on the center hub of the steering, the alarm horn normally fell down when it fell down, probably when it is loaded under the steering wheel. can i do it myself How do I remove the hub of the steering wheel, what kind of view do I encounter? When the airbag burst into my face, will the screwdriver in my hand get stuck in my eye: D be a group, help the bond, I am tired of this car: D I am also thankful to sonerkyl for another problem. For this. But there is another thing that seems to be problematic to my eye. When I load it on the gas, the turbo hose is very swollen, it is next to the same balloon hose, is it normal to have no swelling in it? In other words, when you look at the car, there are 2 balloon pipes at the bottom left, side by side like the crazy on the right.
08.05.2020 20:06 # 2
OguzhanKucuk61
I also have this horn problem. The steering wheel steals from certain parts of the hub. And it is necessary to steal a little hard, not with normal force. I would be glad if there is a solution. Unfortunately, I do not know about Turbo.
08.05.2020 20:06 # 3
GokhaN
Did you get the original hose or sub-industry?
horn thing straight logic is already two metal ends on the right and left of the airbag touch each other, completing the circuit and the horn is working. If the belly is down, it is her but you can break the bandage of the fucker who knows
08.05.2020 20:06 # 4
eeccaa
https://www.youtube.com/watch?v=efıhozmacls
I dismantled the hub using this video. You can also watch and try. It is not possible to open the airbag when the ignition is off. Of course, you still need to be gentle when removing and plugging in its socket.
08.05.2020 20:06 # 5
AllyDrago
There is no problem with the hose I originally attached to the hose, it swells when I press the gas. next to the inflated hose, it's the same, it doesn't swell. Is it normal that it doesn't swell?
08.05.2020 20:06 # 6
pepecura
If the horn thing is pushed, the rectification is removed and taken care of, is this hose swelling not going to happen? How does the turbo hose blow in the radio hose?
08.05.2020 20:06 # 7
AllyDrago
can we clean the intercooler
08.05.2020 20:06 # 8
cr1me
the same problem is with me to press the horn instead of the middle of the navel, press the parts on the right and left or from the bottom
08.05.2020 20:06 # 9
doganatak
I add a few photos in the links on the subject in this way I handle my own horn maybe useful problem I http://forum.peugeotturkey.com/forum_posts.asp?tıd=44142&title=206-korna-sorunumu-hallet
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
