Horn Problem
08.05.2020 17:19 # 1
Oaytekin
Hello. I reviewed the guides before I wrote the message, but either I couldn't find the manual for my car or I was unable to find a title in the manual. I have a horn problem that has been going on for two days. It doesn't play in any way. There was a similar problem with my previous vehicle, but it was playing fine, at least when it replaced the battery. This time, I guess the problem is different. First of all, insurance came to my mind, but a symbolic legend was not used in the table. Frankly, although it is 2012, the most electronic vehicle I ever got was my 2005 vehicle. Therefore, I did not dare and look at the insurance one by one. Possible information will be deleted or some other situation. My priority question is, if it happens to me in another example (such as Signal), would it be okay if I remove the fuses one by one and try? My main question is, if there is no problem with the insurance, what are your estimates about the source of the horn problem. Thank you from now. & Nbsp;
08.05.2020 17:19 # 2
barutcu17
I did not play when I went to the service, I said, they chewed dust between the plates, they worked, they got a little job
08.05.2020 17:19 # 3
haakaannn
My horn may be broken, too, I changed it & nbsp;
08.05.2020 17:19 # 4
impact
I was singing like a young cock, I removed the bumper, I looked oxidation, etc. There was also a 12 TL of them, I bought it like a monster ..
08.05.2020 17:19 # 5
transform609
We are pressing the airbag part in the middle of the steering wheel.
08.05.2020 17:19 # 6
Aziz
There can be many reasons, I recommend you to use violence. Should someone hold down the horn and hit it with the condition that it will not break, it will recover if some dust has entered. (board type object is my recommendation) If it does not improve, you will go new, you will have the most expensive 20 TL ferrari horn and 10 TL labor. If the new one does not improve, if the fuse is not a room, you will turn to the horn button, which is the worst option.
08.05.2020 17:19 # 7
mev347
For example, there is the same problem in me, but I found the solution to connect the horn to the tape handle on the side. Of course, a temporary solution.
08.05.2020 17:19 # 8
Oaytekin
First of all, thank you for your comments. I couldn't follow the forum for a while. When I went to my electrician, he said that one of the cables was not working due to lack of contact. It resolved the problem in about 10 minutes. Thank you, I did not take money, I drank my tea :) As you mentioned, I was afraid of the airbag wrapping most of all, thankfully, we did it. Thank you again for your interest. & Nbsp;
08.05.2020 17:19 # 9
mev347
We are glad that you get it done. In this period, there are few masters who do not receive money for small jobs. Even those who want 10 TL to change insurance.
08.05.2020 17:19 # 10
vosvosmania
greetings. I have 2005 Partner 2.0. Like many peugeot users, my horn is problematic. Interestingly, however, it works when the ignition key is not attached. If I put the ignition key back in and turn it, it stops. It doesn't work again until I remove the ignition key.
Has anyone happened before? & Nbsp;
08.05.2020 17:19 # 11
uzunogluosman
[QUOTE = vosvosmani A] greetings. I have 2005 Partner 2.0. Like many peugeot users, my horn is problematic. Interestingly, however, it works when the ignition key is not attached. If I put the ignition key back in and turn it, it stops. It doesn't work again until you remove the ignition key.
Has anyone happened to you before? & Nbsp;
< div> teacher I have the same problem. How did you solve it? Can you help? & Nbsp;
08.05.2020 17:19 # 12
aydinbslm
do I have the same problem?
