Home screen problem
08.05.2020 16:23 # 1
ßaris
friends bought a tape recorder DEH-2300ub yesterday at 206 yesterday. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. I would be glad if you help.
< img src = "http://i1100.photobucket.com/albums/g405/Otobanfaresi/IMG0188A.jpg" border = "0" />
08.05.2020 16:23 # 2
It's definitely a connection problem. Did you connect the direct sockets?
08.05.2020 16:23 # 3
ßaris
yes, I plugged the two sockets from the original tape with the cable coming out of the box.
08.05.2020 16:23 # 4
yavuz25
The clock does not go to the memory section. If you have the connections checked by a good master, your problem will be solved. "Wink"
08.05.2020 16:23 # 5
ßaris
Thank you guys after we went to the electrician, I guess we will not go any more :)
08.05.2020 16:23 # 6
ßaris
it hasn't passed yet but if you get a hand.
sarış 2012-01-30 20:03:39
08.05.2020 16:23 # 7
neco79
[QUOTE = Order] friends bought a tape recorder DEH-2300ub pieone yesterday or 206 yesterday. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. I would be glad if you help.
friends have the same problem there is. I wonder if friends who can find solutions can help.
thanks a lot.
08.05.2020 16:23 # 8
sinangndz
[QUOTE = Order] friends bought a tape recorder DEH-2300ub pieone yesterday or 206 yesterday. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. I'd appreciate it if you help. [/ QUOTE]
does the car have a steering wheel control?
08.05.2020 16:23 # 9
neco79
[QUOTE = sinangndz] [QUOTE = race] friends got yesterday pieoneer DEH-2300ub tape to 206 yesterday, I installed it myself. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. [/ QUOTE]
Does the car have a steering wheel control? [/ QUOTE]
I have a steering wheel control, sir. from the new model.
08.05.2020 16:23 # 10
sinangndz
[QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = order] friends got yesterday pieoneer DEH-2300ub tape to 206 yesterday. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. [/ QUOTE]
does the car have a steering wheel control? [/ QUOTE]
has a steering wheel control, sir. from the new model.
then the product below operates both the steering wheel control and the date and time on your top display.
08.05.2020 16:23 # 11
neco79
[QUOTE = sinangndz] [QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = order] friends bought a tape recorder yesterday at 206 pioneer DEH-2300ub. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. [/ QUOTE]
I have a steering wheel control, sir. the new model.. [/ QUOTE]
masters. I bought the intermediate cable, the steering control is working, but the problem of freezing on the screen is still not over. I wonder if anyone can help. It bothers me very much, I travel for 2 hours and the clock stays in the state I first move.
08.05.2020 16:23 # 12
sinangndz
[QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = order] friends got pieer DEH-2300ub tape to 206 yesterday. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. [/ QUOTE]
masters. I bought the intermediate cable, the steering control is working, but the problem of freezing on the screen is still not over. I wonder if anyone can help. It bothers me very much, I travel for 2 hours, and the clock stays in the state that I move first.
08.05.2020 16:23 # 13
neco79
[QUOTE = sinangndz] [QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = neco79] [QUOTE = sinangndz] [QUOTE = order] friends got pieerer DEH-2300ub tape yesterday to 206. I realized later that the date was not written on the screen and that the clock did not change. When you press the button on the left of the screen, the date comes and the time is updated, but when I turn the ignition off and on again it becomes the same. [/ QUOTE]
masters. I bought the intermediate cable, the steering control is working, but the problem of freezing on the screen is still not over. I wonder if anyone can help. It bothers me very much, I travel for 2 hours, and the clock stays in the state I moved first. >
there is no master. Original product I brought from England. & nbsp;
08.05.2020 16:23 # 14
hasiko
just unscrew the battery, wait a bit, then plug it in again. you will see everything will be okay. I had the same problem but I figured it out. be late to everyone
08.05.2020 16:23 # 15
berker2004
how to disassemble the battery head yaw
08.05.2020 16:23 # 16
howard
[QUOTE = berker2004] how to disassemble the battery head yaw [/ QUOTE]
clamp is red, probably plastic & nbsp; lift it up then lift the cable that touched the battery upwards, the battery head will be removed :)
08.05.2020 16:23 # 17
howard
[QUOTE = hasiko] just remove the battery head, wait for a while then plug it in again. you will see everything will be okay. I had the same problem but I figured it out. everyone is well past [/ QUOTE]
haha turkish style, turn it on and off :) joke, the friend says right, resetting, remove yourself, unplug yourself, if there is no wrong connection.
08.05.2020 16:23 # 18
Gokhan Cetin
I saw such a problem in a few people, not in the original confirmation of the vehicle.
08.05.2020 16:23 # 19
berker2004
friends, we changed 206+ tapes, when I reset the battery, how do I set the clock again?
08.05.2020 16:23 # 20
Alicilik
[QUOTE = berker2004] friends have changed 206+ tapes when I reset the battery how do I set the clock again as if I remember the date and time settings of the tape from the tape [/ QUOTE]
I answered on the other side
