hk when the contact is opened, the tape will reopen.
08.05.2020 19:43 # 1
seamad
Friends, I bought a pionner bt6750 tape, I am very pleased, at least I do not have any punishment while talking on the phone anymore. When the bluetooth connection is lost and it is not automatically reconnected, it can be prevented from closing and opening the contact.
08.05.2020 19:43 # 2
mimit
I use the same device, the friend who installed it said that the tape will be activated when the doors are opened from the remote control, but I said it would be okay but he said that he did not find it useful and I don't know how he did it, but when I open the door from the remote, the tape does not work, only when I open the left front door, the tape starts to work, I think it is due to you I do not have the other problem you are experiencing, that is, the tape does not turn off at the moment of starting, my vehicle is 406. If you want to visit one of the installation services, there is definitely a solution.
08.05.2020 19:43 # 3
seamad
[QUOTE = mimit] I am using the same device, the friend who installed it said that the tape will be activated if the doors are opened from the remote control, but I said that he did not find it useful, and I don't know how he did it, but the tape does not work when I open the door from the remote, the tape starts to work only when I open the left front door. I guess I do not have any other problems that you experience due to this, so the tape does not close at the time of starting, my vehicle is 406. If you want to stop by one of the installation services and tell the situation, there is definitely a solution. [/ QUOTE]
Hello, where did you install the assembly? I would like to see you there too thanks.
08.05.2020 19:43 # 4
Alicilik
It changes from tape to tape, but for post-2002 206,
The yellow / green thick cable is usually chassis. The continuous feed next to it is +12
In the 4 series of sassene, the contact just below is + 12, and below it is the trigger + 12.
You can connect the tape's memory cable to the side of the chassis.
you will connect the trigger cable to the two golds in the 4-series.
08.05.2020 19:43 # 5
fætih
you have to congratulate the connecting friend. What kind of logic is the opening of the tape when opening the doors: D
two 12v comes to the car, one is always connected to the contact.
08.05.2020 19:43 # 6
seamad
By the way, the tape opens when I open the doors from the remote :) sometimes I get nervous, I close it manually without getting out of the car, then it doesn't open when I open it from the remote, but when the tape is turned off by itself, it bangs blast when it is turned off from the remote :)
08.05.2020 19:43 # 7
Gokcesel
When I had the tape installed the first time, I adjusted the contact, I close the contact, lock the doors, but the tape closes after 1 minute, and the tape was opened when the doors were opened. Now when I open the ignition contact, it opens, when I start, it closes and re-opens mine
08.05.2020 19:43 # 8
Sercan Mungan
He said that I was connecting to the ignition when I was assembling in my car, but when he opened the car, it turned off after 2 minutes when it was locked. Isn't it connected to the ignition?
08.05.2020 19:43 # 9
Mesut48
My teacher Ali should have written the prescription.
New tapes have all kinds of nature LOL
