Hk Semi Automatic Transmission Failure.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 21:17 # 1
sercanokten
Hello friends,
I have 208 models of 2012 model semi-automatic. He started to leave me on the road lately, I want to share with you the possibilities I guessed more or less.
1- There is a spring squeaking noise from the gear action when I shift or close the vehicle, but I did not have any problems in using the vehicle. Do you think this will cause me problems in the future?
2- The gearbox malfunctions and leaves me on the road. I guess why he did it because of the overheating of the robot because of the overheating in hot air and congested traffic. After the engine cools for 5-10 minutes, it returns to its original state. There is also no fault record related to the gearbox in the vehicle brain. (The car does not go after malfunction, there are gears when you want to go, but when you hit the throttle, the car heads off)
3- I think the gearbox failure is caused by the robot overheating. I noticed that my estimate is when the coolant is below the MINIMUM level. (Coolant level decreases in hot weather even though I don't know why). Do you think there is an overheating situation in the engine cooling water robot against the possibility of cooling?
Thank you in advance for your comments and ideas.
from sercanok 2019-07-24 11:53:08
08.05.2020 21:17 # 2
erdem_usta
Mr. Sercan, I have the same problem. I continue to research. One of the craftsman said it might have originated from the press pad. He said we would change it and try. But I need to determine exactly not by trial and error method. Did you find a solution? in erdem_us 2019-08-25 09:47:58
08.05.2020 21:17 # 3
erdem_usta
800 TL labor required to replace the pad Angry . I say the gearbox oil has worn out, but the masters say it is not from him. I'm going to a few more sanjimanciya. in erdem_us 2019-08-25 09:45:05
08.05.2020 21:17 # 4
sercanokten
Hello there. I was suspicious of the press pad, but it would not be right to say that it is literally from him. I advise you to change the gearbox oil, it will reduce gear tones between gear shifts and provide fluency. Currently, I am of the opinion that it is malfunctioning due to the decrease of cooling water. In the near future, I will make a detailed fault detection from the authorized service, and share the information on the subject.
08.05.2020 21:17 # 5
erdem_usta
[QUOTE = sercanokten] Hello. I was suspicious of the press pad, but it would not be right to say that it is literally from him. I advise you to change the gearbox oil, it will reduce gear tones between gear shifts and provide fluency. Currently, I am of the opinion that it is malfunctioning due to the decrease of cooling water. In the near future, I will make a detailed fault detection from the authorized service, and share the information on the subject. [/ QUOTE]
It may make sense with cooling. When the air conditioner turns on, I don't know if the fan is working, I almost don't have the problem. I want to change oil but masters waste money, these are robotic sansziman. They said it goes with the same oil for life. He said the same in the service. I want to start by changing the oil. I will go to another sanjimanciya on the recommendation. I share information too. Also thanks for the information
08.05.2020 21:17 # 6
erdem_usta
SSercan, is there any improvement? I could not go to the service yet ...
08.05.2020 21:17 # 7
kimiraikkonen
About the first problem, I hear the squeak when maneuvering when parking at low speeds in hot weather. It is heard when you press the brake pedal and pull. I even put a video on Youtube. The oil in the bellows to which the robot arm is attached may be missing. I had it after the engine wash. A sound that can be heard when the ignition is turned on halfway.
08.05.2020 21:17 # 8
erdem_usta
[QUOTE = kimiraikkonen] About the first problem, I hear the squeak during maneuver when parking at low speeds in hot weather. It is heard when you press the brake pedal and pull. I even put a video on Youtube. The oil in the bellows to which the robot arm is attached may be missing. I had it after the engine wash. A sound that can be heard when the ignition is turned on halfway. [/ QUOTE]
This problem seems to be chronic. Because I have it too. I am going to solve this warming problem, but I am looking for someone to shoot a spot. Unfortunately I have no money to spend on trial and error system. I'm already paying credit.
08.05.2020 21:17 # 9
talip206
When it heats up in semi-automatic systems, it is caused by 90% pressure pad. Pray that there is no robot malfunction. Because it is quite costly.
08.05.2020 21:17 # 10
erdem_usta
You are right . I took it to the private service yesterday. When they said pressure pad, I said replace pad. it was very thin and even started to burn. The pad has been replaced, the gearbox oil has been changed. Coding was done. The first test drive was fine. I will stop for a long time and try again.
08.05.2020 21:17 # 11
erdem_usta
[QUOTE = talip206] When it heats up in semi-automatic systems, it is caused by 90% pressure pad. Pray that there is no robot malfunction. It's very costly because. [/ QUOTE]
08.05.2020 21:17 # 12
erdem_usta
When Sercan Bey received advice from several services that pressure should change the pad, I decided to renew the pad. Do you have any improvement?
08.05.2020 21:17 # 13
frknhacioglu
Guys, I don't have a problem right now, but what is the average replacement time of the press pad? How many km should I change? Can anyone share the information?
2015 208 1.6 HDI Semi - Automatic.
the frknhaciogl 2019-12-10 11:57:21
08.06.2020 16:50 # 14
saintalcala
Hello friends, I have a 2017 model semi-automatic 208 I have been using it since January 2018.I have been using it since January 2018.It is quite satisfactory, but when I go somewhere, I enter the gas station and start the car, or when I leave the eco and come back to auto or r, it sounds like plug, tuk. I changed 3 services for 1 year, they could not do it. I think it is chronic now. The vehicle is at 40.000 Parts changed from the warranty; -Transmission oil 3 times-Flywheel set 2 times-Gearbox brain 2 times-Operational 1 time-software 15 times Now I use 12,000 dir. Let me pull to the right, or wait and get up a little later, it sounds like something like this is ripping.
09.06.2020 08:59 # 15
[QUOTE = saintalcala] Hello friends, I have a 2017 semi-automatic 208 I have been using it since January 2018. I want to know if there is anybody alive. I have changed 3 services for 1 year. I think it is chronic now. The vehicle is at 40.000 Parts changed from the warranty; -Transmission oil 3 times-Volant set 2 times-Gearbox brain 2 times-Actional 1 time-software 15 times I'm using dir, let me stop on the long road, pull to the right, or wait and get up a little later, it sounds like something like this is ripped. [/ QUOTE] First of all, welcome to us. Sir, it is normal to have sound in semi-automatic devices, but the condition of the sound is of course important, if you can actually shoot a video, it would be good. Also, the transmission acceptance was done in the authorized service.
10.06.2020 14:03 # 16
uzunca961
Welcome teacher, As far as I remember, the gearbox in you was old type robotized. It sounds similar to me too, but if I say it every 3 or 5 days, it's okay. If yours is more than this, it is useful to show it to someone who understands this gearbox without causing bigger problems in the future.
14.11.2020 01:18 # 17
Muhammedertugrul
Mr. Sercan greetings. What happened to the last situation? Did the printing pad replacement solve the problem?
14.11.2020 01:20 # 18
Muhammedertugrul
Hello, Mr. Erdem, did the pressure lining replacement solve the problem? What is the latest situation?
14.11.2020 09:22 # 19
erdem_usta
Hello, Mr. Muhammed. Yes, the problem was solved after the pressure lining and gearbox oil changed. Because the pressure lining is very worn, it causes warming. Gear shifts etc have also improved.
14.11.2020 12:40 # 20
Muhammedertugrul
Thanks, I am relieved 😊 I left it, I will change what you used transmission oil for the pressure pad change
Page : / 2
