Hk Oil Pressure Indicator
08.05.2020 14:13 # 1
seLim
Hello, I don't know if I have happened to you before, but when my vehicle is switched on, the temperature and oil indicator are working, so their level shows whatever the moment is, but immediately after the starter is pressed, the OIL indicator immediately drops to the bottom level. (The oil level in the engine bar is normal.)
Oxigen 2010-03-31 17:11:06
08.05.2020 14:13 # 2
hasimayaz
What is a vehicle?
08.05.2020 14:13 # 3
I think 106 gti, Hasım brother
08.05.2020 14:13 # 4
seLim
106 gti
08.05.2020 14:13 # 5
hasimayaz
Is there an oil pressure indicator in 106 ?? I think you're talking about the dipstick on the digital panel.
08.05.2020 14:13 # 6
seLim
I know it as oil pressure, I am not a digital model 98 meter indicator counter next to the tachometer
08.05.2020 14:13 # 7
hasimayaz
I haven't seen it before .. probability of having sensor or indicator problem .. I know the instrument panel is very expensive 106 also .. If you want an opinion with efe, you can try to plug it in. It is difficult to find any other problem.
08.05.2020 14:13 # 8
seLim
I understood that it might be caused by a large blade sensor. There is no other explanation.
08.05.2020 14:13 # 9
peugeotefe
you can reach me 24/7 how can you not reach my brother 0531 363 67 66.
08.05.2020 14:13 # 10
seLim
yesterday i called efe helped you guys i will come at a convenient time but the room will be the weekend but i was not at work just gave the line 542 .. this is why i could not reach it;) i think there is no explanation other than the client for your attention ..
08.05.2020 14:13 # 11
okankrgz
If we come, we cannot go there, we close the efe shop together, but die Gülme most likely from the client, the indicator is active when the ignition is switched on but not activated when it starts.
08.05.2020 14:13 # 12
seLim
: D there are some minor deficiencies. If we come as the arrow says, we will have a hard time in the evening if the issue is 106: D
08.05.2020 14:13 # 13
peugeotefe
I am always single, we did not have a little morning for 106 lovers
08.05.2020 14:13 # 14
seLim
Gülme eyw efe 106 does not know what else does not use the event .. Oxigen 2010-04-02 14:52:04
