Hk not working 307.
08.05.2020 15:04 # 1
06ef
Hello friends, I shared with you that my car did not work last week and that the master changed the gas pump, but my car stopped working again after 3-4 days, 4th or 5th. When I started the starter, I started pumping the gas a few times, we called the master, worked with him, then the man went: D do you think what is the source of the malfunction? Everything has been changed in the 90000 maintenance in the authorized service 3000 km ago ...
08.05.2020 15:04 # 2
metin
Since the engine does not work when gasoline and electricity are not available, I don't think you will have an electrical problem in terms of maintenance, then it may be compatibility or a master & nbsp; wrong connection & nbsp; maybe it is required software but I think the problem is related to gas pump.
08.05.2020 15:04 # 3
06ef
If he did another master, he said play with insurance or something but what you said might be the wrong link, he changed 9 days ago dha pump
08.05.2020 15:04 # 4
metin
There is a lack of interest, he said, play with insurance.
& nbsp;
I suggest you show it to someone who is competent.
& nbsp;
the seals were missing oil so I think we each gave a separate price.
& nbsp;
did not give a price at a master The seals tightened the drain plug or cut the leak and the felts were intact.
& nbsp;
is whatever I mean, show it to someone who does the research job well, it is not something that cannot be solved as a result, if the man is a master, I am sure he will solve it. respects.
08.05.2020 15:04 # 5
Muhammet CAKIR
needs to know what the master is doing, he said, play the queue or something, he does not control himself, right or wrong, I think these are the master's heat
08.05.2020 15:04 # 6
gozem
How much did you pay for the sister gas pump, my diesel pump was canceled today
08.05.2020 15:04 # 7
06ef
thank you for the comments. we gave the pump 300 with workmanship bro
