Hk Height Of Vehicle.
08.05.2020 18:09 # 1
serkanklc
Hello,
Although there are 17 "wheels in my vehicle, the rim is very idle compared to the other 207's. The distance between the rim and the fender is too much to me. And the gap parts of that area are also disproportionate. The distance between the top and the tire is too much, between the left side and the tire. The distance is different in the distance between the tire on the right side and the rear bumper.I am using 205/45/17 tires right now.If I use 205/50/17 the tire looks as if it will rub against the interior of the rear bumper.
08.05.2020 18:09 # 2
kursat3006
It is a little much like this, but I think this is normal. Is there a torsion event in 207?
08.05.2020 18:09 # 3
serkanklc
If you are talking about torsion balls, I know I have it.
08.05.2020 18:09 # 4
serkanklc
I do not want to press the vehicle. If the 207's suspension is hard on anyway, the interior of the vehicle will become unbearable.
08.05.2020 18:09 # 5
kursat3006
What is the situation ahead? Without a ball, you can pull down the spindle that the car is connected to without playing the spring, and just close that gap in the back.
08.05.2020 18:09 # 6
samet206
If there is a torsion, it is a normal image on the unprinted vehicle, this is just an imbalance, as if the rim and tire gauges were not calculated as thin as possible, maybe 16 rims and a wider sidewall tire would still be that distance.
08.05.2020 18:09 # 7
serkanklc
I just looked at the rear tires of the 207s with the original rims. They have this disproportionate situation. The gap between the top of the tire and the top fender is different, the gap distance between the left side of the tire and the rear door is different, the gap distances for the right side of the tire and the rear bumper look different. I use 205/50/17 snow tires on the front of the vehicle. The front seems to be printed nicely, but the back is offside. Let me take a look at this torsion event over the weekend, it seems like it would be better if we could pull a tooth down.
08.05.2020 18:09 # 8
tongucuk
this stance, the stance of the vehicle in its idle state is normal, it just hit my eye, the right and left gaps of the tire are not equal. With the left tire, I hit the sidewalk with the effect of the impact, and this kind of image was formed, and if I am not mistaken, did the axle or rot be warped? I didn't know, I got stuck
08.05.2020 18:09 # 9
Unfortunately, there is the same incident in my 307. So it's not something special to your vehicle. I do not want to wear a spring, I do not want to lose it almost in comfort, regardless of the brand, even the originals bounce. But on my 17 rims, I do not look at all, I am a bit complained about it.
08.05.2020 18:09 # 10
serkanklc
Right and left distances bother me a lot. It looks very disproportionate, the vehicle is almost zero, there was no hard movement, I just looked at other urban move vehicles on sahibinden.com. Right and Left are disproportionate.
08.05.2020 18:09 # 11
kursat3006
[QUOTE = ramazanturan81] this stance, the idle of the vehicle as it is normal, it just struck me something like the right and left spaces of the tire is not equal. I don't know if there was a 206 but I hit the curb with the left tire on the sidewalk, this kind of image was formed with the effect of the impact, and if I am not mistaken, what was the axle or rot was distorted? I didn't know, I got stuck
Victorious dervish at work :)))
08.05.2020 18:09 # 12
tongucuk
exactly Big smile I'm stuck in my head
