Hk Bluetooth Connection. - Resolved.
08.05.2020 17:33 # 1
mranda
Greetings friends;
I have 307 HDI technopack model vehicles. When I try to connect via Bluetooth, the phone says the connection is denied and it gives an error saying "painting conditions not met" on the vehicle's road computer screen. I searched on the internet but I could not solve why. There are English sites but I still couldn't solve it:) & nbsp;
Have you ever encountered or resolved this problem before? he is dealing with this.
08.05.2020 17:33 # 2
Alicilik
[QUOTE = mranda] Greetings friends;
I have 307 HDI technopack model vehicles. When I try to connect via Bluetooth, the phone says the connection is denied and it gives an error saying "painting conditions not met" on the vehicle's road computer screen. I searched on the internet but I could not solve why. There are sites in English but I still couldn't solve it:) & nbsp;
Note: many friends are sure he is dealing with it.
he will be pairing, not paint. There is an error in the connection. They offer 3 options for this:
1-Consult the service and reset the system (registered information, etc.)
2-Disconnect the battery terminal
3-Find and replace the system's fuse on BSi
If not, the service road is seen.
08.05.2020 17:33 # 3
hsnsnl
Can you see the vehicle when you turn on the bluetooth on your phone? After turning on the bluetooth wire, open the contact of the vehicle and then introduce the wire to the vehicle .. the vehicle will be inoperative;)
08.05.2020 17:33 # 4
mranda
[QUOTE = Buying] [QUOTE = mranda] Greetings friends;
I have 307 HDI technopack model vehicle. When I try to connect via Bluetooth, the phone says the connection is denied and it gives an error saying "painting conditions not met" on the vehicle's road computer screen. I searched on the internet but I could not solve why. There are sites in English but I still couldn't solve it:) & nbsp;
If it doesn't, the service road is being seen.
I got it, brother. Thank you very much. I will write the result here.
08.05.2020 17:33 # 5
mranda
[QUOTE = hsnsnl] Can you see the car when you turn on the bluetooth on the
wire? After turning on the bluetooth, it will open the contact of the vehicle and then introduce the wire to the vehicle .. the vehicle will be inoperative;)
my brother I see the vehicle from the phone but the connection was refused says. I was doing the vehicle with the normal ignition on, not working. To the service if there was no experience of my recruiting friend.
08.05.2020 17:33 # 6
hsnsnl
[QUOTE = mranda] [QUOTE = hsnsnl] Can you see the vehicle when you turn on the bluetooth on the
my brother I see the vehicle from the phone but the connection was refused says. I was doing the vehicle with the normal ignition on, not working. If the appeal is not an experience of what my friend wrote, go to the service.
After seeing [/ QUOTE], I'll match and be warm .. & nbsp; what are you writing as a password?
08.05.2020 17:33 # 7
mranda
[QUOTE = hsnsnl] [QUOTE = mranda] [QUOTE = hsnsnl] Can you see the car when it turns on bluetooth on the
my brother I see the vehicle from the phone but the connection was refused says. I was doing the vehicle with the normal ignition on, not working. If the appeal is not an experience of what my friend wrote, to the service. I can't come :) While pairing, the phone says "CONNECTION Denied" and gives "pairing conditions not met" error on the vehicle.
08.05.2020 17:33 # 8
mranda
If not, the service road is being seen.
Greetings again;
Battery I unscrewed the pole head did not happen again. I removed it again, after waiting for about 2 minutes, I put on the pole and waited for a while, opened the contact, started the car, turned off the contact, opened the tape, the problem was resolved. Thank you bro.
