Hk 308 Printing Pad Replacement
08.05.2020 18:27 # 1
kemalakkan
Greetings friends, I can not write anything for a long time, since I work abroad, 308 im waiting in the garage at home, after a month, I will see my car, whatever my car is short. experienced masters said it would be better if you change the pressure caused by the pad, I want to ask how much it costs in the service outside, what would it cost outside?
08.05.2020 18:27 # 2
hsnsnl
I do not think it will cause trouble, it is okay.
08.05.2020 18:27 # 3
yawruaslan
it will be salty in service, you can get it out with a familiar good master at a more affordable price
08.05.2020 18:27 # 4
Alper134
If the tool is 90, there is a fixed flywheel, while 110 is a movable flywheel. Even if it is 110, there is no need to change the flywheel of the vehicle at 40 thousand km.
Apart from that, the pressure pad and ball, the clutch set, will change in any case. The price of the clutch set is 250 TL, the gearbox needs to be lowered, 150 TL is labor, so it explodes to 400 TL in a peugeot special service outside.
But I don't think it will be less than 700-800 TL in the authorized service.
08.05.2020 18:27 # 5
ahmet_bjk
The service requires 250-300 labor, the master in the industry is 150, and the part prices are a bit more expensive than usual in the service.
