Hk 307 maintenance.
08.05.2020 16:31 # 1
cermiki
Good day to you guys. 2006 I have 1.6 HDI 90 hp 307 vehicles. It approached 80,000 km. I want to change my car's clutch set. I did part research on the clutch set on the internet. However, I need to make a change whether the flywheel is complete set or clutch set. I don't know much about these issues. Many thanks to all of you in advance.
Note: I have read a few conversations about this topic on the site. But when I read them, I was even more confused.
08.05.2020 16:31 # 2
If your thrust pad has run out and has damaged the flywheel and worn the flywheel, you should replace it. but if the flywheel is not damaged, only the pressure changes to the pad service fee of 1,500 TL (parts only) and 2,900 TL (Peugeot MEPA provided the price in question) if you have it out, 300 to 400 TL parts and labor included.
08.05.2020 16:31 # 3
cermiki
Thank goodness the print did not have a problem in the pad is not finished. I just want to keep the precaution.
08.05.2020 16:31 # 4
[QUOTE = cermiki] Thank goodness the print did not have a problem, the pad is not finished. I just want to keep the precaution. [/ QUOTE]
If your brother has plenty of money, give me a prayer. change door wicks or "Ouch"
08.05.2020 16:31 # 5
cermiki
"Smile" I changed it now I changed it, I find it more difficult. After a few months, the twins will be born. No money after that. & Nbsp;
08.05.2020 16:31 # 6
[QUOTE = cermiki] "Smile" I changed it now and find it more difficult. After a few months, the twins will be born. No money after that. & Nbsp; [/ QUOTE]
oo go buy the car =) you will sell it in the future =)
08.05.2020 16:31 # 7
06OzGuR06
The track must be original & nbsp; and & nbsp; It would be nice if there is solid workmanship. Prefer special service.
But why is it changing? What is your complaint about clutch set?
08.05.2020 16:31 # 8
cermiki
I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp;
08.05.2020 16:31 # 9
cermiki
[QUOTE = xSOLOx] [QUOTE = cermiki] "Smile" I changed it now, I find it more difficult. After a few months, the twins will be born. No money after that. & Nbsp; [/ QUOTE]
oo go buy the car =) you will sell the car in the future =) [/ QUOTE]
Man, let's take a wind from the mouth. I am very satisfied with my car. "Smile"
08.05.2020 16:31 # 10
06OzGuR06
[QUOTE = cermiki] I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp; [/ QUOTE]
I understand it pleases you to be careful. "Wink" & nbsp; & nbsp ; you are right, female drivers are always going half clutch. "LOL"
It would be better to change it early, of course. As I said, the piece must be original and the workmanship must be intact. "Smile"
08.05.2020 16:31 # 11
cermiki
[QUOTE = 06ÖZGüR06] [QUOTE = cermiki] I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp; [/ QUOTE]
Volant will not change then as far as i understand. If I am wrong, please correct it.
08.05.2020 16:31 # 12
06OzGuR06
[QUOTE = cermiki] [QUOTE = 06ÖZGüR06] [QUOTE = cermiki] I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp; [/ QUOTE]
The flywheel is not changed if the wear is low, but if it is excessively worn. In general, the flywheel is damaged and changes for the
, where most vehicles go to the service by burning the pad, but it may not change if yours is not too worn. border = "0" alt = "Smile" title = "Smile" />
08.05.2020 16:31 # 13
cermiki
[QUOTE = 06ÖZGÜR06] [QUOTE = jermiki] [QUOTE = 06ÖZGüR06] [QUOTE = jermiki] I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp; [/ QUOTE]
, where most vehicles go to the service by burning the pads, but it may not change if yours is not worn too. So it becomes evident when the
is removed. border = "0" alt = "Smile" title = "Smile" />
Thank you bro. Thanks a lot for the information.
08.05.2020 16:31 # 14
06OzGuR06
[QUOTE = jermiki] [QUOTE = 06ÖZGüR06] [QUOTE = jermiki] [QUOTE = 06ÖZGüR06] [QUOTE = jermiki] I am the 2nd owner of the car. I also bought 60,000 km. now at 80,000 km. The owner before me was a woman. already it needs to be changed between 90-100 thousand under normal conditions. When I add the female factor to this, I said, let me put a little bit of change forward. & Nbsp; [/ QUOTE]
We thank you. I wish you a smooth and enjoyable ride. "Wink"
08.05.2020 16:31 # 15
sahin-peugeot
If your vehicle is 1.6 110, it must change in the flywheel, 110s will play the flywheel & nbsp; it will break the clutch when it breaks the clutch, if you want, you can install the clutch with 90 flywheel at the clutch change, the flywheel will be lifetime.
08.05.2020 16:31 # 16
06OzGuR06
06ÖZGüR06 2012-01-14 12:53:21
