Hk 206 air filter suction.
08.05.2020 20:04 # 1
dejawu1978
hi aleyküm gentlemen, I did not have the diffuser of the air filter, I took it from the net, I realized something while installing it, the filter box does not suction, I close the hole completely with my hand, there is no suction in the vehicle and it does not give any reaction. what's the problem with the slice ... I want to disassemble and clean the butterfly, but at this time, let's not take a look when we say, let's make an eyebrow that will come out, adaptation etc. Or if a piece is broken in the butterfly, let's not keep it in my hand and give it to the industry ... I'm glad
08.05.2020 20:04 # 2
You can disassemble and clean the butterfly, just don't move the moving part inside. it will help you if you watch the sample video.
https://www.youtube.com/watch?v=_hzn0utxap0
08.05.2020 20:04 # 3
dejawu1978
[QUOTE = sonerkyl] You can disassemble and clean the butterfly, just don't move the moving part inside. it will help you if you watch the sample video.
I watched these videos a lot and did I need to adapt?
08.05.2020 20:04 # 4
If it doesn't move the butterfly in it, it won't be a problem. When we move it, the vehicle in which its position is broken does not work properly. therefore, adaptation is required.
08.05.2020 20:04 # 5
tigerland
The electronic throttle, on the other hand, has the possibility of calibration deterioration. If it breaks during calibration, the vehicle shakes a little while it is cold. he did a little after cleaning it, we'll calibrate it sometime :)
